Results 1 to 10 of 11
Thread: Hole in petrol tank
    Feb 2010
    Caulfield Nth
    Hole in petrol tank
    Can anyone recommend the best way to patch a very small hole in my 1957, 88 petrol tank. would solder be best or a fiberglass patch. thanks Nick
    Crafers West South Australia
    Quote Originally Posted by nicholascummins View Post
    If you have it out and it is clean and empty, solder would be best. If it is still in and is weeping the special epoxy petrol tank repair stuff is quite good. Should be able to get it from auto parts shops.
    Feb 2010
    Caulfield Nth
    thanks for that it is out and clean and empty so I'll give the solder a go.
    olmate Guest
    Buy yourself some Red Kot. You wont beat that stuff - guarenteed for 25 yrs and you can order it from Brissie I think.
    Have used it on three other landies and its the simplest means and seals all the holes / splits and prevent further rust inside as well.
    Fuel Tank and Radiator Service - Red-KoteĀ® - Fuel Tank Liner
    Feb 2010
    Caulfield Nth
    thanks for that great solution
    Bunbury, WA
    Quote Originally Posted by olmate View Post
    I "Red-Kote'd" the tank from my 86" last weekend after I found a few leaks in the seams. Seems like really good stuff. I will refill it this weekend and see how it works.
    holes in tanks
    Hi All
    posting this again
    use jointing cement (plastic water pipe type)
    add 25% cleaning fluid to it to thin
    rotate to coat
    allow to dry
    works
    far cheaper than brand names
    works better
    have a tank done 20 years ago
    Ian
    Do you mean methylethylketone?
    Aaron.
    Narre Warren South
    If it's just a pinhole a temporary solution is PTFE tape wrapped round a self tapping screw. Screw it in and job done.
    A mate did this to a Mk3 Cortina years ago as a temporary fix and sold it 2 years later with the screw still keeping the petrol in !
    If you intend to keep the vehicle maybe one of the earlier suggestions may be more appropriate.......
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    australia
    hi red kote last anther 50 years jim
