Results 1 to 10 of 22
Thread: New Fridge needed - ARB or Engel???
    Sydney, NSW
    Guys n' Gals,
    Im in the market for a new fridge.
    Ive always had (and sold in the UK) Engel's before. I know they are very good and indeed still have a 17L Engel.
    Im now looking at replacing the 45L Engel I had with a 60L Engel or ARB.
    Is there much difference in quality / reliability / power usage?
    One thing I like about the 60L Engel is its landscape lid opening, the ARB lid opens along the narrow side, which I suspect will prove problematic behind the front seats of the Defender, the 40L Engel door was only just OK.
    Thoughts and opinions please.
    J
    Regards,
    Jon
    Scarborough, QLD
    It might sound trivial, but the 2 things I love about my Dad's ARB are the light inside the lid, and most of all the removable bung - wish all fridge manufacturers had this. It makes cleaning them out so much easier.
    richard4u2 Guest
    i would go for the engel with the new motor
    Mar 2010
    Bundoora
    Hi Yorkshire Jon,
    For what it's worth I had to replace my Engel 40lt two years ago - the compressor failed and it was going to cost me about $800 in repairs. I was on a trip at the time and the dealer/service agent I went to didn't have the Engel I wanted in stock. As I was desperate and couldn't be without a fridge I had no alternative but to purchase a 60lt Waeco - and I've never been happier.
    The Waeco has a landscape fridge but it you can hinge it from either side you prefer. This means I can put it on the left or right side at the rear of the vehicle and still have the temperature read-out and controls at the rear so that I can see them through the rear door (of a Discovery).
    I was a died-in-the-wool Engel fan, now I'm a died-in-the-wool Waeco fan!
    Regards,
    Ron
    Feb 2005
    interesting topic, i have two engels a 32L and 40L and hoping never have to purchase another
    what price is the ARB?
    i reckon both you have mentioned along with waeco are all quality units these days........tough call
    i have never owned a danfos fridge therefore never been able to measure current draw but i reckon it maybe better than engel's swing motor.
    i cannot recall seeing my engels draw less than 2amp when running, keep in mind its normally cycles about 50% of the time
    i would suspect the figures below does not take into account the lid being opened, ambient temp items being placed in etc etc. and they dont mention cycle on cycle off times
    i might wack the amp meter onto my engels to refresh my memory on current draw
    Attached Files Attached Files
    Avoca Beach
    One interesting thing that I recently learned is that the Engel swing motor has a "soft" start so doesn't spike the voltage down on startup, whereas the Waeco and others with Danfoss do have a load spike on start up.
    I reckon this is the source of a lot of the Waeco problems when the wiring is insufficient, and should allow an Engel to operate with a lower battery level than the Waeco etc.
    I have a low battery cutout on my Engel at 11.5 and all things being equal it should go longer than a Waeco with the same cutout, because of the initial start up draw on the Waeco.
    I enjoyed this first hand yesterday when we had a power outage and I connected my home fridge to my 1KVA peak 800W Yamaha. I had a couple of stalls when adding the load , but it ran easily once going and the fridge motor is only rated at 1.5 amps or 360watts.
    Regards Philip A
    Nundle
    Quote Originally Posted by Ranga View Post
    The newer Engels have a light as well.
    Numpty
    REMLR No 143
    Ipswich Qld
    I have a Evacool 60 Litre.I have tested the draw and on cycling mode it is 2.9 amps dropping back to 2.5 amps.That was on 5 on the thermostat. I tested it for 24 hours and the draw remained the same keeping the freezer section at -18c and the fridge section under 5c which is recommended as optimal for fridges.
    Apr 2010
    Connolly, WA
    Bit of the "cat among the pigeons"...
    I have a 60 liter National Luna. Bit up price wise on the comparable Engels, ARB's and Waeco's, but they are still the choice of the United Nations and in particular UNHCR for transporting medical supplies and the like around deepest darkest Africa.
    Used them on a few humanitarian runs around Central Africa and in my opinion they are a bit of a pricey investment, but you get what you pay for...
    South Yundreup,WA.
    Quote Originally Posted by Watpub View Post
    Hi Yorkshire Jon,
    Regards,
    Ron
    $800 for a 40 litre compressor, I think someone was rorting you. I just had my 60litre replaced $550 and that is the more expensive compressor in the range. Now just had the power supply go to so another $420 odd for the unit alone, still cheaper than the $1700-$1800 replacement cost for the 60litre.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
