Results 1 to 10 of 17
Thread: Landy wont start
    Natt Guest
    Landy wont start
    Morning all, I have a 2006 130 T/D i went to start up the landy and it wont start battery is good, every thing is normal when the key is turned right to the last bit when starting, i have checked the fuses near the gear shift and the ones under the drivers seat, is there something im missing? i mean lights indercaters wipers and everything else is like normal. any thoughts?
    Feb 2010
    No where
    has it got fuel in it
    Feb 2010
    Aussie
    Checked that it isn't immobilised?
    Natt Guest
    Quote Originally Posted by wanglemoose View Post
    Yes, i should of explained a bit better sorry, when i say it wont start i mean when the last bit turning the key i have nothing, no power to turn the starter over, all the lights on the dash is normal as per usual but turn the key that last bit and i have nothing, thanks for trying thou
    Natt Guest
    Quote Originally Posted by Xul View Post
    thats what it feels like, I tried the buttons on the key, is there any where else i should be looking at
    Dec 2009
    Maitland - NSW
    shouldn't there be a light somewhere on the dash/steering column so you see it it disarms? THis happened to me, my immobiliser was bumped and had a loose connection. Everything you described was exactly the same.
    This light is also used to override the immobiliser manually
    Natt Guest
    Quote Originally Posted by rutmutt View Post
    Ok, i went out and closed the landy up and immobilised it all worked as normal but the red light on the dash is blinking alot faster than normal, where from here
    Garfield, Victoria
    Quote Originally Posted by Natt View Post
    I presume we are talking 130 Defender TD5 here? In which case I would be surprised if an immobiliser problem stopped it from cranking. It would be more likely to start and then stop.
    It sounds more like a starter motor problem to me. Have a look at the cables connecting to the starter solenoid, and I would also be carefully checking engine/transmission earths.
    Lionel
    Jan 2010
    labrador
    i had the same problem some time back
    turned out being the starter solernoid
    scotty
    Natt Guest
    Quote Originally Posted by scottygc View Post
    scotty
    Is there a way of checking this?
