Results 1 to 3 of 3
Thread: Door Repair Panels
    Alderley, Qld
    Door Repair Panels
    Does anyone know of an Australian supplier for Door repair panels?
    Failing that dimensions of the section would be good and I can see if a sheet metal fabricator can make some up.
    Thanks,
    Russ
    Coffs Harbour
    Check out FWD Motors at Yeerongpilly.
    It's been quite a while since I was last in there, but I do remember them having all sorts of goodies for Landies stashed in the back.
    Cheers, Matt.
    Narrogin WA
    Quote Originally Posted by Brisruss View Post
    Thanks,
    Russ
    Do you mean the door skin; the steel frame supporting the skin; or the window surround?
    New window surrounds are available from Paddock and Rocky Mountain.
    Door skins, if not corroded, can be salvaged by unbending the folded edge and transferring to the new frame.
    Someone with a good bender can make the frame - preferably a Magna Bender,
    Cheers Charlie
