Results 1 to 8 of 8
Thread: 94 disco v8 hard to start
    Feb 2011
    tara qld
    i just bought a v8 94 disc i gave it a good rev through the gears the yesterday and now today when i started it it sounded like a hydraulic lifter noise it went away and then returned but after about 6 hours of driving it went away and now i have it home it starts fine then low revs around my property and it starts the noise again i am afraid i have maybe bent a pushrod or it maybe just needs a thicker oil aparently the last owner used 10.40 oil i was thinkn using magnatec its been great in all my other cars this car has done 235000 any ideas ?it also is hard to start once it has been stopped for a while winds over and then u have to put ur foot down to the floor then start it again any ideas?
    Back down the hill.
    I use Magnatec, brilliant stuff.
    Kingston, Tassie, OZ.
    At 235K it would almost certainlyhave a worn out cam and followers. The hard starting could even be a dying fuel pump, leaking injector/s or faulty fuel pressure regulator. Best bet is to attach a fuel pressure gauge and check the pressure at the rail. There should be a schrader valve on the drivers side of the fuel rail if late 1994 (Update) model. If not, then you will have to tee into the supply line at the back of the rail drivers side.
    JC
    Feb 2011
    tara qld
    thanx will try that is it a big expensive job doing the cam and followers ?
    Feb 2011
    tara qld
    thanx do u run that in ur disco and do u have any noises
    Feb 2011
    tara qld
    hi thanx its a march 94 will get it looked at
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    the title of your thread is correct, get a diesel...............
    Feb 2011
    tara qld
    lol well i wouldve but i want the noise lol
