Results 1 to 10 of 15
Thread: Any advice,thinking of buying 2001 disco2
    camm Guest
    Hi guys,
    I'm looking at a 2001 es tdi5 4speed auto, it has about 185000k on the dial, Ive never owned a disco before and just wondering if there is any particular issues on this model I should be cautious of??
    Any help would be great.
    Toowoomba
    Welcome!
    I have an 02 Td5 and it's fantastic.
    Things to look for...
    1. Service history!!!!
    2. Oil in injector loom plug at the ecu
    3. Make sure the oil pump bolt has been loctited
    4. Check for CDL internals
    5. fuel block leak
    Search is your friend.
    All the best.
    Waz
    camm Guest
    Thanks wazz,
    Ill check all that out.
    Sully Guest
    Service history.
    Read, research, read some more, research more, read reviews, test drive, inspect, research, read, take your time finding the right one, test again, ask questions on here... Buy!!
    Grin....
    I'm sure you get the drift. Best of luck! Be sure to keep us updated with your progress.
    Jan 2011
    abs, tcs lights staying on when driving
    signs of oil leaking on the brake backing plates of the rear brakes.
    oil leaks from transfer case, engine, transmission and diffs.
    vibration from engine at idle in gear when stationary.
    vibration between 90 and 115 kms hr.
    vibration at 2250 rpm when free reving and while driving
    universal joints in the front and rear prop shafts have been replaced with servicable ones. ie grease nipples in all unis.
    cracks in rear rubber coupling where rear shaft bolts to the rear diff
    inside drivers door where the hinges are isnt cracked when the door is opened as wide as it will go
    chips in the windscreen
    all switches inside the car work ie. windows, fuel release and so on.
    check for the car leaning to the right or sagging on the drivers side.
    check that the trans shifts smoothly and the torque convertor locks at about 80 km hr
    check low range works.
    if it has sls suspension that it works
    coolant looks like coolant and not mud.
    service history
    and so on. Hope i didnt scare you but i would check most of these things on an car i buy.
    Michael.
    May 2003
    On The Road
    ensure that ALL the in-dash warning lights self-test on start-up,,,
    and there are a few--
    I'm sure theres a pic in here somewhere---
    Mar 2009
    Port Stephens N.S.W
    Nope Pedro ... there's a handy video though !
    http://www.aulro.com/afvb/discovery-...ndy-video.html
    Kev..
    2014 Isuzu MUX LST with fruit
    2008 Isuzu D-Max
    2015 Kimberley Kamper "Classic"
    Gone ... 2004 D2a Td5 Auto "Classic Country" Vienna Green
    May 2003
    On The Road
    I love it when a plan comes together
    Oct 2010
    Caloundra
    Quote Originally Posted by Pacemaker View Post
    What's with this one? Mine did it when I bought it, but seems to have stopped after I took the car on a long drive (600k day after I bought it).
    Jan 2011
    Generaly this is a sign of engine and or gearbox mounts sagged. If its gone away after a long drive possibly the exhaust mounts. I say this because once the exhaust mounts get hot they soften up slightly. Also maybe the exhaust moved during the long drive.
    Either way if the vibration is gone then be happy.
