I'm on all original at 39000km . The pads look good for another 15000 or
more . Discs are fine . No towing and few hills . I use the gears alot .
Discs usually last 2 sets of pads on D3 18" ers......
Hi All
How long should one get out of a new set of front rotors. Two services ago I had new break rotors fitted front and back and pads of coarse. Also hand break gizmo. So only 24k later the fronts are warped(slight shudder when applying break lightly ) I have done no water crossings in this time. Had noticed the shudder at 12k but dealer could,nt so nothing was done at this time, now they feel it.
cheers connock
PS Its a 06 TDV6 SE
On the Commodore, I didn't replace my rotors until well over 200,000km. Never machined. I have heard stories of 20,000km between machining.
On the hybrid ('81 RRC chassis), I have just had them replaced. I have driven it over 200,000km but I don't know the history of the previous 200,000km.
It depends a lot on the way you drive. I know people who are constantly heavy on brakes but I rarely use mine preferring to let the engine slow down the car and then applying the brakes at a much slower speed.
With the warping, they probably got too hot at some stage. Are the discs vented?
The discs aren't vented . The system is designed to use
2 sets of pads for one set of discs . Alot of Yanks went for harder
pads , thinking more mileage , but they just eat the discs.
Lower wear rate systems don't give the same high-brake effect.
Remember when discs lasted forever , and pads for years .......
stopping distance was terrible !
Yes, discs are considered a consumable nowdays.
I'm getting about three sets of pads per disc. The pads are lasting around 60,000 to 80,000km. I do a lot of country miles.
Thanks guys
I thourght I would have gotten around 80 to 100k out of a set, I have warped a set on my defender by driving through deep water and the breaks were to hot, but this was not the case , just road some sand use and a little lite towing. Never mind its only money
Since posting this question the dealer has rang to tell me the trans fluid is a bit discoloured and smelly this was only changed three services ago. BUGGER.
Wouldnt drive anything else tho
Thanks again for the input
Once the asbestos was dropped from the pad compounds and various levels of metal included, the wear rates climbed dramatically. A good proportion of the dust seen on modern wheel rims is not the pads, it is from the rotor. A side effect of all this, is that brake rotors are now a disposable component, and have come down dramatically in price.
There are some pads using new technology out there. Do some comparisons, and read the service book before buying a new car. Some new vehicles are listed to have rotors and pads replaced at 40000klms. A rude shock, as they are not a warranty item.
Part of the modern world we now have to live with.
D4 2.7litre
I am only a couple of thousand off my 48K service. Wonder if mine need replacing?
Shall let you know.
Cheers, Craig
