Results 1 to 3 of 3
Thread: H/T instead of A/T?
    Brissy! No flannos here!
    H/T instead of A/T?
    Hi all,
    I have a 2nd set of rims for my D2, and have to soon purchase new rubber for the steering end. I am thinking about putting a set of H/T on the front as most of the km are bitumen. Of course that frees up my 2nd set for gnarly A/T's when we do actually 4wd.
    I did this with a D1 I had and it worked well but that was with steelies.
    Anyway, anyone have any thoughts or advice?
    Secondly, without asking for price info, does anyone recommend a tyre place in the north or nw burbs of Brissy? 245/70 R16's.
    Ralph
    Mar 2007
    South Arm, Tasmania
    I'm running GT Radial Savero H/T's on my D2 at the moment. Most of my driving is on either bitumen or sand, and I've been pretty happy with them so far. They're relatively cheap compared to others out there, but I haven't been able to fault them - have had them on for a couple of years now.
    I've got the 16x8 rims on mine, so was able to go for a larger tyre than original (in both width and diameter). Only thing I had to do was reverse the spare wheel carrier so that the spare clears the bumper when you close the door.
    Cheers .........
    BMKAL
    VIC
    There isn't much point in running a second set if they're A/Ts, the advantage of the A/T over the H/T will be so minimal it won't be worth the effort changing four wheels over to go 4wding.
    I was running two sets, A/Ts and M/Ts and even then the M/Ts ended up staying on full time as the road handling was fine.
    I've gone back to running two sets, A/Ts and Centipede knock offs.
