Originally Posted by
miles
My vehicle is a Series I Disco 3.9/4.0L fitted with a Series II Thor inlet manifold. Plus it runs on duel fuels.
Now the outside diameter of the Bosch throttle body is 82mm. (Air cleaner side). It is much bigger than the gas mixer that was fitted on the old seriesI manifold.
I have had trouble saucing a larger mixer locally. I was given a mixer that was apparently off a Ford. The outside diameter is 82mm but the section that fits over the throttle body is only 74mm. So I made up a stainless steel sleeve to fit it onto the throttle body.
Last week I had my Disco dyno tuned and the results showed that the vehicle was 20 to 25 hp down on previous tunes.
My dyno tuning man and friend David, told me that the most likely cause was the gas mixer I fitted. The gas mixer has an internal hole of only 46mm and this was placing a high restriction on the incoming air, through the throttle boby. When I switch over to gas, the performance is like disconnecting two cylinders. Dave recommended that I find a larger gas mixer and if I cannot get a larger mixer, start saving my money for a sequentiel injection system.
Now I know a lot of you guys have fitted the Thor manifold to the 3.9 V8, but do you use lpg as well and have you come across this problem?
What we need is a gas mixer with a 82.5 mm section to go over the throttle body and a throat around 55 to 60 mm. Is this possible?
