Results 1 to 10 of 14
Thread: D2 Windscreen
    Brissy! No flannos here!
    D2 Windscreen
    Hi all,
    I am about to replace the windscreen on my D2 and am a bit hesitant.
    When I had the screen on a previous D1 replaced by a reputable firm in Melb, they underwhelmed me. Took them nearly a week to obtain one, then it didn't appear that the fellow had changed many discos before.
    Anyway, is there a preferred screen replacement mob in the north of Brissy? Or more so, anyone to avoid?
    Ralph
    Mar 2010
    Ralph
    Check the D2 section on this forum firstly, as this is where this query should have been posted. Secondly, I'm pretty sure 9 out of 10 will recommend a genuine screen as the replacement as the after market part tends not to seal as well.
    Not sure who to use in Brisbane though.
    One other thing, make sure the plenum of you car has no cracks in it prior to having the windscreen replaced. Mine was damaged when replaced about 2 years ago. I think the company had 'Instant" in it's name, (they are on the south side). They were cheap but at the end of the day not very good.
    Andrew
    Yes Andrew,
    Did a search and nothing close came up in the D2 forums so I posted in general. I don't mind if it's moved....
    I reckon I am pretty savvy, but what's a plenum when referring to windcreens?
    Yep, thinking genuine also. But then where from?
    Ralph
    Mar 2010
    Ralph
    The plenum is the black plastic moulding in front of the screen where the windscreen wipers are attached. Can be a expensive part to replace and tend to become brittle after being in the sun (for 7 - 10 years).
    I know of another guy who had his replaced and he suggested you have to remove the entire bonnet to replace the windscreen. Sounds drastic but not sure if I miss heard him.
    Andrew
    Two Rocks WA
    Hello the windscreen is not hard to do and the bonet coming off is 4 bolts. I had mine done last last year $275 fitted and they came to me . I am very happy with the job but I did take off the plenum myself so I know it coundnt /wouldnt be broken except by me. It was very easy to take off and refit.
    Shop around as the bigger guys quoted me over 600 to do the same job...
    Brad in perth
    Range Rovers Have Charactors inside them
    LROCWA Ex member 23 years
    1971 Series 2A
    2004 Discovery2a V8 Auto
    2003 Discovery2a TD5 Manual
    1982 4door man (sadly now gone)
    1989 Vogue auto
    2011 TDV8 Vogue
    What would life be without a Rangie?
    Mar 2010
    Ralph
    Found these links in the D2 section.
    http://www.aulro.com/afvb/discovery-...ght=windscreen
    Others in amongst them of relevance (D2 search 'windscreen')
    Andrew
    Jimboomba, QLD
    I had mine done by O'Briens. I went with them simply because it was insurance job and they were the recommended glass repairer.
    They did a fantastic job! They had all the trims and glass in stock. They did have to remove the bonnet. I'm not sure what the job cost but they did a very professional job.
    -- Paul --
    | '99 Discovery Td5 5spd man with a td5inside remap | doesn't know what it is in for ...
    | '94 Discovery Tdi 5spd man | going ... GONE
    Try RACQ glass they done one in the D1 for my son cost $250.
    Bigmac
    Back down the hill.
    Ralph, I know it's the wrong side of town for you but I have dealt with this mob, excellant service and back up if required. They can do custom glass if required.
    Autoglas-Stieger
    windscreen ipswich road rocklea - Google Search
    Goolwa SA
    Quote Originally Posted by awabbit6 View Post
    Same here. I had mine done at O'Briens Geebung. They kept the vehicle overnight to make sure that the sealant cured properly.
    Stephen.
