Results 1 to 10 of 17
Thread: MATSO'S MANGO STYLE
    MATSO'S MANGO STYLE
    Have just started the process of trying to copy Matso's Mango Beer.
    For those who dont know, Matso's is a specialty brewery in Broome with quite a good variety of essentially hand made beers.
    24 exceptionally ripe mangos cut and blended into a purée and put in to freezer which will then be defrosted to increase the liquidity of the juice and reduce the slime like consistency.
    Base for the brew will be a Belgian white much like a Hoegaarden but minus the orange and coriander.
    Mango purée makes about 4litres and will use 2 litres per brew.
    Really want to do this with a liquid wort but can't find anyone in WA who makes just wort and U-brew etc don't make it for sale unless your doing a full brew. At this stage will just go with the basics that Brewcraft supply for the Hoegaarden to start and progress from there.
    Andrew.
    Sent from my backyard TeePee using smoke signals.
    Ellendale Tasmania.
    Try these guys in Perth, they have a range from Brewers Selection wort kits.
    Home brew : Perth, Western Australia
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    Mate!!
    These guys are just down the road from my office!!
    Will ring them today!!!
    Williams West Aust
    Hey Andrew.
    havent been too impressed with that mob,they are the original hombrew people in WA.
    Brewcraft in Osborne Park are very helpful.
    With the fruit its extremely important to blanch it in boiling water,it kills wild yeasts on the fruit that will ruin your brew.You can use the water you boil the mangoes in,only need to boil for a minute.
    GOODLUCK
    Let us know how it goes.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Hey Andrew.
    GOODLUCK
    Andrew
    I rang this morning and he wasn't overly welcoming as I would have expected for a potential new customer, but it seems he is the only liquid wort supplier.
    Brewcraft have unfortunately no liquid worts which I really want to try. Ossie Park is where I usually go and he did give me a $15 voucher for sprouting about how good the Fat Yak is resulting in 2 customers buying before they left.
    He did say it all came from the east so it's travelability worries me slightly as does it's possible age, but yet to have a look and nothing ventured nothing gained.
    With the mango, I'm freezing it now and then going to defrost it in a pot on the stove slowly, might even steam it but will get it just off the boil and then cool before adding.
    I read somewhere else about over ripe fruit and yeasts etc affecting it so as I've already blended it, is the best way to heat treat it.
    Will keep a running log of it.
    Andrew
    Ellendale Tasmania.
    Andrew I found this on the web;
    Brew Your Own: The How-To Homebrew Beer Magazine - Techniques - Brewing with Fruit: Tips from the Pros
    Below is from a page of the site
    Brewing beer with fruit
    Tips
    The Tips
    • When making a fruit beer, use a neutral yeast.
    • Try using a fruit puree.
    • Add fruit to taste throughout the process.
    With the success of the Razz Wheat, Belli has had a lot of practice making fruit beers.
    “You don’t want to overpower the fruit flavor with something else, like hops or yeast,” Belli says. A Belgian or German yeast can add flavors you may not want. Instead he recommends using a neutral yeast.
    So what’s the best form for your fruit? For homebrewers, using fresh or frozen fruit isn’t too much of a problem, according to Belli. “I suggest steeping the fruit in hot water, about 180° F, for 15 minutes to pasteurize it. Whole fruit with skin should be crushed before adding to your fermenter. I choose not to boil fruit to keep more of the fruit aroma intact. If you do boil the fruit you will set the pectin, which will result in a hazy finished beer. To break down the pectin try adding the enzyme pectinase at the end of fermentation.
    For simplicity’s sake, Belli suggests using a puree instead of fresh fruit. “I have used fresh fruit, and it was a lot of work,” he says, recalling a time when he was colored red up to his elbows from crushing blueberries.
    He warns that purees will vary from lot to lot, just as fresh fruit varies from crop to crop, and their flavors fade over time. A recent batch of Razz Wheat tasted quite different from the usual brew, because the puree wasn’t as fresh as it normally is.
    That beer was made at the eastside brewery. “It seemed lighter; it didn’t seem as raspberry as we expected,” he says, but he attributed that to the new brewing system. “Then we made a batch at the pub and it went like wildfire.”
    But the next batch was made at the pub with the same puree as the first one, and they discovered the puree was responsible for the difference.
    “I didn’t realize it until it was out of the fermenter,” he says. “Then, you’re kind of stuck.”
    Add fruit to taste as you go along. “I add it to the fermenter and let it ferment out, pull a sample, and taste it,” he says. “If you keep (the fruit) clean, and it’s pasteurized, you can just dump it in and the beer takes off again right away. As long as it’s still warm, the fruit sugar will allow fermentation to continue.
    “If you do get a stuck fermentation, don’t be afraid to keep adding yeast after you’ve added the fruit,” he says.
    Once you find a fruit that works, don’t stop there, Belli advises. “Don’t be afraid to experiment with different fruit beers. Based on the success of Razz Wheat, I tried a cherry beer. Customers who didn’t normally drink Razz Wheat like the cherry beer because the flavor was more subdued.” When the cherry was gone customers were clamoring for the next fruit beer.
    “Over the past four years I have tried raspberry, peach, apple, blueberry, and even plums in beer,” he says. “Some brewers scoff at the fruit beer style, but when customers are making requests it’s hard to say no.”
    That’s the joy of brewing at a brewpub and later going to a micro, Belli says. “You can experiment at the pub and get customer feedback. If a beer is well received it can be brewed on a larger scale at the micro.”
    Stan Hieronymus and Daria Labinsky are authors of the Beer Travelers Guide, which lists more than 1,700 US brewpubs, bars, and restaurants that serve flavorful beer.
    Hope this helps, Baz.
    Cheers Baz.
    2007 BMW R1200GS
    The 180F steep is basically what I had in mind with putting it in the pot to just off the boil, however I didn't want to boil it in case it caramelizes the flavour of the mango.
    I guess as it's already puree'd, maybe put it in a ziplock bag and stick in 180F water.....
    That's quite a good site Baz! Feeds my dream of starting a micro! We have a couple of real good ones within 20 minutes of where I live near the Swan Valley. Good to see it's starting to balance out the wineries.
    Same down around Margaret River area too, lots of little micros popping up.
    Now, who's got a spare $700k I can borrow.....
    Ok brew went down today.
    Went to Malthouse in Welshpool yesterday, chose not to go with the liquid wort he had, 35c inside and it looked like it had been there for a little while along with most of the stock he had.... So, after ducking down to RichardK's place to pickup the two EAS units he was giving away, (big thanks mate. For me that's the score of the year!) dropped into Brewcraft Ossie Park and had a quick chat.
    I ended up with a Brewcraft Hoegaarden (funny that, never seem to leave without one these days... ) and a 5g sachet of Lalvin FC1118 Saccharomyces Bayanus yeast.
    This is a champagne yeast selected for it's vigorous fermenting capability of fruit. Used on it's own in beer wort has been guaranteed by Brewcraft without the need for any additional brew yeasts.
    I was going to fore go the malt in the Hoe kit and get a single sprayed white wheat but a quite like the flavor and form of this one and a single might make it a little too wheaty, overpowering the mango.
    As for the mango, 2lbs went into 23L total volume. Put 2L of water in a pot, got it to simmering then cut the frozen block from a 5L ice-cream container into 1/4's with each one weighing 1lb each (old time scales, no metric.... ) and added one to the pot. Slowly defrosted it, swirled and tasted. Not enough, add another block... disolve... taste.... perfect!
    Cooled it down, mixed up wort and malt, cooled then mixed together.
    The yeast was a dry yeast but requires hydrating in 50ml of Luke warm water for 15 minutes.
    Added to the wort in the fermenter and was surprised as the slurry hopped back to the top!!
    So now it's wait and see. Will check it in the morning for bubbling and decide if I want to add a fairly neutral type yeast or a pectin yeast if it starts looking cloudy. Wasn't boiled so thinking this won't be needed.
    The Safbrew WB06 that normally comes with the Hoegaarden went into a spare Tooheys kit I had lying around with 200mls of Bickfords Lime cordial and 1 cup of castor sugar.
    It's only been going for 3 hours and I'm already impatient!!
    Andrew
    Well, the champagne yeast is rocking!!
    May have to cut another hole for a second airlock it's gassing that much!! Has developed a 1inch thick head inside the fermenter and the smell is to die for!
    Simones a bit miffed by the smell but then she doesn't appreciate art
    Ellendale Tasmania.
    Don't worry about an airlock, just cover the lid with a tea towel until it settles then you can put an airlock back in.
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
