Thread: Disconnecting D2 SLS compressor air lines - help anyone please?
    canblogerra Guest
    I've looked at the 2 air lines from the compressor every which way but can't figure out how to 'disconnect inlet and exhaust pipes' as the RAVE manual says. I'm amazed no one else doing this job, and apparently there are lots judging by the posts, has ever had enough difficulty to mention it!
    Photos of the suckers are pointed out in attachments. Please tell me how these connections work.
    For anyone interested my SLS 30A fuse keeps blowing unless I disconnect the compressor. Tried directly connecting 12V (don't have anything above a 10A meter) and only sparks fly ...
    Cheers.
    my house in brisbane
    the first one should be a squeeze and pull, and the second one you push the grey collar in and the line should come out.
    Hope that works for you
    canblogerra Guest
    Thanks for that. I've put off pulling these tubes off for now but am sure I'll have to tackle it some day. On the 1st photo, I assume I squeeze the tube because the connector is quite solid; and on the 2nd photo, that grey ring was already hard up against the connector when I started by jamming a screwdriver into the slot and levering to the point where a bit snapped off on the other side (you can't see) and the photo was taken.
    I ended up pulling the compressor apart under the car with air hoses attached - the compressor was siezed but came loose with a minute of hand twisting, clockwise then anticlockwise, on the rotor. I'd heard some were quite messy inside but mine was relatively clean with only minor solidification of grease.
    It should be noted that my car, and hence compressor, had not been operated for at least 4 months (ps - the A/C compressor pulley had siezed too!) but at $800+ I strongly recommend trying a repair before replacing.
    Happy motoring - only a surging at high speed to work out once run in (600km to go) ...
    May 2009
    Tatura, Vic
    Not sure about the first pic but in the second pic "that_kid" is correct. Just push the collar in and then pull the line out. Some times the line can be a bit tight. Don't be afraid to pull it hard.
    Dave.
    May 2009
    Tatura, Vic
    Quote Originally Posted by canblogerra View Post
    SWMBO Fairlane has self leveling rear suspension. A new compressor from Ford was also about $800. I got an after market compressor for $200. I reckon it is also better quality than the Ford one. It took a bit of mucking around plumbing it in but it works a treat.
    I got it from here.
    Air Ride Suspension Supplies - Air Ride Suspension Supplies - Air Suspensions Systems and Auto Electrical Products for Rods, Customs and Classics
    Dave.
