Results 1 to 10 of 17
Thread: Technical Question re D3/4/RRS Air Suspension
    Rockylizard Guest
    Gday...
    We all know, and accept, that LR state that a WDH is NOT to be used with the D3/4/RRS.
    Without a caravan/heavy trailer attached to the D3 there is obviously 'balanced' pressure/weight on the front wheels and rear wheels to maintain steering, braking, traction.
    So, when I connect my van to the towball, the D3 does not sag at the rear but automatically levels itself with the added weight on the ball.
    Does the air suspension restore the pressure/weight 'balance' to the front wheels to maintain steering, braking, traction? Does it maintain the weight distribution over each of the axles - van, vehicle rear and vehicle front?
    If this is how LR designed the suspension setup, can anyone provide me with authoritative advice and/or source to confirm, and describe how it works?
    NSW SW Slopes
    The air suspenion system maintains height only. More weight at the rear makes the vehicle lower at the rear and higher at the front which is detected by the height sensors so the air volume in all the air springs is adjusted to make all the height sensors read the correct height.
    Rockylizard Guest
    Gday...
    So with the caravan/heavy trailer connected to the D3, I have lost some steering, braking and traction efficiency at the front of the vehicle?
    Isn't that dangerous?
    From the sensation of towing my van, I would suggest it does more than "just adjust the height" as it feels very normal to drive when the van is connected. So I am kidding myself then?
    No it's not particularly "dangerous" - search for WDH on this forum and get a plethora of arguments and counter-arguments from the religious wars this topic has generated.
    The short story is that your EAS can react faster and without rebound when compared to a WDH system. So overall, you have greater control.
    Gordon
    NSW SW Slopes
    The vehicles have a reasonably long wheelbase and reasonably short overhangs so loads on the back don't affect the vehicle as much as some other vehicles. Add the stability control and the trailer/van effect that's felt on older vehicles is greatly reduced on these vehicles. Without a trailer or van attached, try throwing the vehicle around and feel how it wont let you unless DSC is disabled (as much as it will). The suspension height control reacts slowly by design but DSC is super quick.
    Melbourne, mostly
    Quote Originally Posted by Rockylizard View Post
    Gday...
    Yes, there's an element of danger. That's why trailers need to be driven differently.
    If you connect a trailer to a Disco then you are creating a moment which increases the force on the rear wheels and lessens it on the front. That's basic physics and no different to any other vehicle. A WDH lessens this effect, transferring mass from the rear to the front wheels (and other factors as well). Discos cannot take WDHs but are quite capable of towing 3500kg. A WDH is basically there to stop the rear sagging - the EAS keeps it level hence no WDH required.
    If DSC or its close friend TSC has to kick in then the trailer is poorly set up.
    Lots more to it than that but bottom line is the Discos are great towcars but do not remove the need to set trailers up correctly and then drive them correctly.
    Melbourne, mostly
    No, it doesn't maintain weight distribution. It can't transfer mass from one axle to another. It can only maintain height.
    NSW SW Slopes
    Something that's often overlooked is that ABS allows rear wheels to do a lot more of the braking when the rear is loaded. Usually too much weight is transferred to the front wheels especially if the vehicle nose-dives, so having less weight on the front wheels doesn't necessarily mean less braking ability.
    Jan 2008
    Have you assessed the weight in the trailer is placing on the hitch, it should not be that much. 150kg? I tow a tonne and a half on a regular basis and I forget sometimes it's there, it's a well balanced load so never had any issues
    G
    Rockylizard Guest
    Quote Originally Posted by Garry View Post
    G
    Gday...
    Van puts 240kg on tow ball ... and van is well balanced ... and it tows with absolutely no problems - uphill or downhill, smooth road or rough road.
    I was just wondering, given the safety advantages of WDH, which I have towed with previously on other vehicles, whether the EAS on D3 was smart enough to actually not just level but also ensure the weight on front and rear was restored to close to 'normal'.
    In some way, I guess it does ... but there is no definitive proof it does so.
    Thanks for all the interest.
