Thread: D4 Filler neck - cant take hi-flo nozzle
    N.E. 'burbs Melbourne
    Has anyone modified a D4 filler neck to take a hi-flo nozzle?
    Some servos only have hi-flo!!!
    Gladstone
    I have... I had a long Rang tank installed.
    There have been comments here that if you are careful you can use a HiFlow nozzle. With the standard filler neck.
    Quote Originally Posted by mowog View Post
    What brand? did they modify the filler neck, replace the filler neck or fit a second one?
    Gladstone
    :: The Long Ranger :: Long Range Fuel Tanks & Long Range Water Tanks ::
    The original filler neck is removed. A single fuel cap still exists but inside is two filler tubes one for aux tank and one for the main. You can fill with high flow nozzles. I wouldn't run them at full flow however.
    If you're careful not to insert the hi-flo all the way, you can manage to fill at reasonable flow rates without triggering the mis-fueling device. Takes a steady hand the first few times until you get it right.
    Gordon
    NSW SW Slopes
    I use a hi-flow every fill although this particular one is not as fast as some. I hold the nozzle hard and square against the filler but have to be careful to stop at the 1st sign of getting blow-back then go slowly from a distance if I want it filled right to the brim. I used a very fast one recently and couldn't fully open the nozzle but didn't make a mess either. I was initially going to fit a D3 filler neck but haven't bothered.
    Does a D3 filler neck take a hi-flo and will iy fit a D4?
    St George Dragons Territory, NSW
    Quote Originally Posted by wozzlegummich View Post
    wozzlegummich,
    D3 certainly does take a high flow no problems, not sure if they can be retro fitted.
    George
    Feb 2010
    Perth WA
    As per Gordon's comment the D4 will take the high flow nozzle, but it is a little painful. I stoppped at the wrong pump once and persevered, but personnally I think it's quicker to use the regular nozzle and not have to concentrate!
    May 2010
    Singleton NSW
    Quote Originally Posted by MartyJB View Post
    Same same.
    But if the normal bowser is already in use, then I will go for the hi-flow.
