Do you mean the Engine-Saver coolant alarm? If so, which model?
I fitted the Engine-Saver combination coolant alarm and head temperature monitor last year and can post a picture of where I located it if this is what you're installing.
 Fossicker
						Fossicker
						Last year there was a bulk purchase of temperature alarms. I know they fit snugly into a compartment on a Disco dash but does anyone have a "trick" way of mounting one in a Defender dash?
Thanks... David
Mellow Yellow
No matter what the problem - there's a solution. You've just got to find it.
2013 Discovery 4 TDV6 3.0
2015 Defender 90 - The TARDIS (Gone)
2003 Defender 110 - The Yellow Peril (Gone but remembered fondly)
2001 Discovery II TD5 (Gone)
1986 County V8 (Gone)
 Fossicker
						Fossicker
						One like that shown in the photo. Temperature Monitor TM2 by Engine Watchdog.
David
I located it on the right hand side of the steering column as the pic shows. Note the small square push button switch which I put in case it was alarming and I wanted to turn it off and keep driving.
On a bright day it can be hard to read but shading it with your hand overcomes this. It's not really an issue. At night it's out of the way and so not distracting.
Mellow Yellow
