Results 1 to 10 of 15
Thread: Handbrake wear
    Handbrake wear
    Can someone please explain to me how the pads in the handbrake can be worn? My D3 has done 96k but I've never applied the brake when the vehicle is moving.
    I would have thought (he says in complete ignorance) that there'd be no wear on the pads, although I can understand that the drive mechanism may wear over time.
    Sydney, Australia
    Unless the EPB has been out of adjustment and slightly on all the time?
    NSW SW Slopes
    Dirt/mud wears the shoes even though the brakes are not applied.
    There's been plenty of that!
    Jul 2010
    FYI - I had my pads and rotors replaced late last year cause they were end of life 100,000km+ and noted by FWD Motors was excessive wear of the rotor bits where the EPB shoes rub. Didn’t matter much cause they were getting replaced.
    This ties in with your experience as the implication was that the previous servicing agent was adjusting the brake shoes too tight.
    Queensland
    Hi folks, do you guys disengage the park brake before moving off or do you just drive off and let it release automatically?
    Always disengage first.
    Sydney, Australia
    Just give a trottle blip before taking off.
    Nov 2008
    if u pull the hand brake wile moving it puts the ABS on anyway, not the hand brake, they ware with the dust, and need to be adjusted every 24k ish,,
    mandurah
    We have always applied and disengaged the handbrake manually.
    D4 2.7litre
