Results 1 to 9 of 9
Thread: L/R Mechanic in Brisbane??
    Sep 2010
    Hi there
    I've just imported my Land Rover Defender into Australia from the UK, have got it rego'd and took it out for a spin around the city. Then disaster struck.....
    The gears wouldn't select properly and instead of engaging they grind against each other....1st...2nd...all the way through to 5th!!
    It happens in Low Range, High Range and has no drive at all. I had it towed to the local garage in Bulimba and they checked it out the next day but couldn't find anything wrong with it?!!
    The gearbox had returned to normal and they couldn't find an issue - but obviously there is one somewhere.
    I'm new to the city and am looking for advice on the best mechanic/garage I can take it to for a once-over. Can anyone help me with the best place to contact??
    The gearbox is an R380 and has worked perfectly for the last five years and is regularly serviced as a matter of course.
    Your help and Aussie mateship is very much appreciated
    Thank you
    Ben Southall
    Feb 2005
    i use M R Automotive on the north side....landy specialist, know there stuff but can take up to two weeks to get your car in
    sounds like your hydraulic system might have just had a hiccup from not being driven
    if you can make it out to ipswich and we can arrange a suitable time I can have a look.
    It sounds like its a fault in the tcase rather than the r380.
    Scarborough QLD
    Ben
    If you need a hand to get it over to Ipswitch to Daves place, give me a call on 0415366536. I am living in Scarborough but I wouldn't mind popping over to Daves place as I have a couple of questions about 300Tdi power improvements for him.
    Provided that's OK by you Dave?
    Ivan
    Sep 2010
    Solution....
    Thank you for your responses guys and girls
    I've managed to get the gearbox selecting again and believe that it may have been the clutch release mechanism getting stuck.
    The vehicle had sat for a year in the UK and then in a container for 6 weeks so things weren't operating 100% correctly.
    As a matter of course I am now sending it to MR Automotive for a once over as a friend lives up near them and I can us it as an excuse to visit...as long as the Landie makes it!
    I now have RACQ cover too
    Appreciate all of your help
    Ben
    Quote Originally Posted by Ivan View Post
    Ben
    Ivan
    if you cant tag in with bensouthall touch base with Ranga, hes lining up to come over for some looksee-ery.
    Quote Originally Posted by bensouthall View Post
    Ben
    Ben
    Hi Ben
    Glad to know it is starting to sort i'st self out. Did think it was the clutch stuck from miss use
    If you need any help or it towed somewhere then give me a shout
    Only happy to help as another person from Hampshire here with a personally imported 300 tdi 90
    Look forward to seeing it around
    Cheers Ali
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Sep 2010
    Aha! Another escapee from Basingstoke, by any chance?
    Quote Originally Posted by Ratel10mm View Post
    Nah other side of the hills
    I am a Winchester boy
    Although have worked in shops in Basingstoke , Petersfeild and other areas
    Sent from my iPhone
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
