Results 1 to 10 of 14
Thread: fuse problem
    Jan 2010
    labrador
    fuse problem
    ive lost my indercators, speedo, fuel gage,temp gauge and rear wiper
    all on a 2000 110
    indercators work when i put the hazard switch on but nothing when i indercate
    checked fues
    the relay on the far right (green ) is very warm
    could this be my problem?
    all other relays were cool to touch
    thanks in advance
    scotty
    North Avoca
    If your fuses are OK (remember there are fuses under the driver's seat) then the hazard relay is likely to be the problem. I don't know where it is but I'm guessing that it's behind the dash.
    Mellow Yellow
    No matter what the problem - there's a solution. You've just got to find it.
    2013 Discovery 4 TDV6 3.0
    2015 Defender 90 - The TARDIS (Gone)
    2003 Defender 110 - The Yellow Peril (Gone but remembered fondly)
    2001 Discovery II TD5 (Gone)
    1986 County V8 (Gone)
    North Avoca
    Stuffed this reply. Please see below.
    Mellow Yellow
    North Avoca
    Ditto. Sorry.
    Mellow Yellow
    North Avoca
    If fuse 21 in the box behind the gear shift is OK (remember there are fuses under the driver's seat - might pay to check fuse 6) then the hazard relay is likely to be the problem. I don't know where it is but I'm guessing that it's behind the instrument pack.
    Of course I'm assuming your set up is the same as in my MY03 Defender.
    Mellow Yellow
    Allestree , its all good.
    Check the small earth wire off the batt, under seat box.
    '99 Tdi 300 130 Twin Cab
    When I'm here I want to be out there.
    Apr 2010
    Thumbs up
    Hi ScottyGC, if all have gone at once, then i'd be along the lines of either of the previous replies from mellow yellow or sly. If it's not a simple fuse or earth wire, grab a test light and check your power and earths to the back of your gauges behind the dash. Process of elimination, if you have no power then start at the fuse/s which provide power to these circuits and check continuity between them, likewise the earths.
    As for your relay being warm, swap your relay around with one of the others that is the same to eliminate this.
    From, here you can start continuity testing, power off, with a multimeter or continuity light, not a test light. Not sure if there are any plugs that connect between all of these that may have come loose, but keep it simple.
    Good luck
    P.S. think i bought that cargo barrier of you a while back
    Jan 2010
    labrador
    well all fuses checked out ok
    even ones under the seat
    no small black wire on my battery but it has been changed to a dual system
    might have to take it to a auto sparkie
    im a very auto eletrical handicapped
    yes fish you did get the cargo barrier from me
    did it fit ok?
    did you sort out your clutch?
    Apr 2010
    Hey scotty, just been looking at the schematic and fuse number 3 in your passenger compartment( guessing they mean the one in front of the gear stick) supplies power to all of the above circuits.
    It should be a 10amp fuse as indicated on the schematic. Just check and see if you can turn your a/c blower fan on as well as this is linked as a switching wire in the circuit. If your blower fan is not working this also indicates that the power feed from fuse 3 is gooooone. Also , your headlamp leveling switch shares the same earth as your speedo, coolant and fuel guages but different power feed, so if this works your earths are fine for your speedo, coolant and fuel guages. This i hope will help tell you that it is the power feed from fuse number 3.
    any questions send another reply and i'll check again.
    Replace it even if it looks fine to be sure.
    Did get the clutch sorted in the old girl, had new suspension put in and sent the barrier to the powder coaters for $40 and fitted the sucker. But i couldn't stop myself from making a set of drawers for the back, piling in the gear, a mate and taking her up the Cape.
    Jan 2010
    labrador
    thanks
    i will check it out
    good news on the cargo barrier and the clutch
