Thread: 130 springs in a 110
    Feb 2011
    Semaphore SA
    Do the rear 130 springs fit straight into a 110?
    I need the double springs to cope with a heavy canopy I want to put on a tray top 110.
    If not...what are some alternatives that people have used?
    The canopy weights between 6 and 700kg (we think) and the springs on the 110 tend to sag a little with it in place.
    Jul 2008
    Lismore NSW
    polyairs might be better if you plan to take canopy on & off (not as harsh unladen), if permanently on heavier springs might be the go
    Brett
    110 300tdi
    Feb 2011
    Semaphore SA
    It will be permanently attached so in that case springs would be better?
    Which leads back to - do the 130 dual rear springs fit into a 110?
    Should do, you'll need the spring mounts for the helper springs.
    Check here -
    http://www.aulro.com/afvb/good-oil/6...t-numbers.html
    If you are carrying a permanent fixed load, why not a single set of heavy springs wound up to match the load?
    Helper springs are there so that unloaded ride quality is not affected by heavier springs.
