That is pretty much how a structural steel portal frame would be erected.
Using a non shrinking grout is important...and the epoxy will probably fit the bill.
I assume that the 10mm plate for each "leg" would have 2 holes and you would use that as the template for drilling the holes in the slab for the chem-anchors.
So it seems sound to me.
Don't forget the photos.![]()
