Results 1 to 6 of 6
Thread: Tow bar bolt thread ? (Defender)
    SW of Geelong
    Can someone please tell me the bolt size and thread pitch of the top 4 bolts that hold a tow bar to the back face of the chassis on a Defender. I'm pretty sure that on late models there are captive nuts in the chassis.
    I'm guessing the bolts are M12 but I need to confirm this along with the x pitch?? x length??
    Cheers, Murray
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
    May 2009
    Tatura, Vic
    Murray, If you can't get an answer here just take one to a nut and bolt place and they will be able to tell you.
    Dave.
    SW of Geelong
    Quote Originally Posted by Mr Whippy View Post
    Dave.
    G'day Dave,
    I haven't got one, that's the problem. I just need to know what thread they are so I can supply them with the wheel carriers where there is no tow bar present. If I had one I would know what it is.
    Cheers, Murray
    '56 SI Ute Cab
    Feb 2009
    Northern NSW
    Will have a look tomorrow and let you know.
    Feb 2009
    Northern NSW
    30mm M12*1.75 with a 18mm head came with the hayman reece setup I have.
    I put 45mm M12*1.75 with a 19 mm head in the top two holes that support the spacer and bottom carrier support. The 30mm ones were only holding by a couple of threads.
    Hope this helps.
    Tod.
    SW of Geelong
    Quote Originally Posted by Rimmer View Post
    Hope this helps.
    Tod.
    You're a champ Tod,
    Thanks for that. I was thinking about 40mm, but 45mm will do just fine. I was supplying 90mm bolts to go right through the chassis, not realising there were captive nuts in the newer models.
    Cheers, Murray
    '56 SI Ute Cab
