Tyre manufacturers make tyres for a wide range of vehicles - not just for one make or model.
It is up to you, the vehicle owner, and then the tyre retailer, to match the best suited tyre to your vehicle, given the vehicle manufacturers specifications.
I used to work for a commercial national tyre company, as a store manger, over a decade ago, and there was still confusion back then over load ratings.
All tyres have load ratings, speed ratings, and pressure ratings imprinted/moulded on the sidewall, the tyre staff only have that information to go by. If you wish to have specialised tyres fitted, it will be at your own risk, and they should tell you that!
I have refused, in the past, to fit 4x4 tyres bought in by customers when I, or my staff, were hesistant about fitting them on the vehicle. I have also refused to sell or fit tyres that customers picked out from the rack as they were not suited for their vehicles either.
Most good tyre stores will look at your placard and make suggestions, they should ask how you use your vehicle (ie 80% off road, 20% on road etc) and make recommendations from there.
I must say though I'm a liitle confused about the 'minimum tyre load' most tyres have a 'maximum tyre load' ( ie max load XXXkgs @ XX psi ) - but I have been out of the loop for a while.
