Rotary Coupler D3
					I have experienced a couple of issues with the SRS & Cruise Control on the D3.
The SRS red light appears on the dash, pretty much straight away upon start up.
The cruise control has also been intermittant.
After a bit of detection work, the both sensors/switch are related.
The run through the Rotary Coupler in the driver steering assembly.
We swapped one over from another car, to see if that solved the issue, and yes it did.
I have had advice that it was an issue in the seat belt clasp, etc etc.
If you find you experience the same issue, explore this option.
I was advise a coupler would cost $680.00 from our local dealership, and would have to order in from the UK.
I went direct to Craddocks in the UK, and they in turn ordered from LR UK.
The cost ended up at $178.00 AUD Landed.
Just thought it would be useful info to someone, if the same issue or symptoms arise.
				Cheers Dave
66 Series 2a
82 RR Classic
86 RR Classic
04 D2a Disco Td5
