Thread: Front bumper rubber strip
    Oct 2010
    Carindale, Brisbane, Qld
    Hi guys
    The rubber (attached) above my bumper is loose and comes out every time I drive (on both sides).
    Has anyone seen the proper mounting of this strip, ie, do I silicone it to the bumper underneath it, or to the panels above it? I dont want to glue it in and then find I have complications in the future if I take my bumper off.
    Thanks!
    Now: 2005 L322 Vogue 4.4 M62TU (Black)
    Before: 2000 P38A HSE 4.6 - stately capability | 2008 Kluger KX-S | 2004 Forester | 2000 Yamaha XJR1300 | 1993 VR Calais | 1974 HQ Statesman - 308 V8 | HT | HK
    Feb 2010
    Townsville, QLD
    From memory it just sits there - no glue or anything, needs to be tucked between the body panel and bumper itself!
    It should be sticky on one side and be glued to the body. I had to use some double-sided tape to restick mine.
    Douglas Park, NSW
    I'm sure it sticks to the plastic bumper, not the body.
    They often come loose though so a dab of silicon will hold it in place. If you have the bar off at anytime, it would pay to remove it altogether & resecure it as you'll find it loose in several spots.
    You are right. I had to transfer it from my rear bumper to the Kaymar rear step bar whne I fitted that.
