Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: CAT 12H Coolant issue
    Williams West Aust
    Our CAT 12H Grader is having cooling system issues.
    It has been overheating.Radiator was found to be blocked with a black sludge.Radiator was removed and rodded,CAT reccomended flushing the cooling sytem adding a liquid clothes detergent.It was flushed with detergent then water lots of times over a week,the correct CAT ELC coolant was then added after running on rain water,daily draining for at least a week.
    The coolant has continued to turn black and is overheating again,mainly when transporting on hot days(sounds like radiator is blocking again).It was just serviced and the sample tests(oil/coolant etc) say the coolant has exsessive iron contamination and to drain/flush/refil ASAP.(I havent seen the test results,the boss told me).
    When you let the coolant settle out in a glass jar the black contamination settles to the bottom of the jar,it doesnt feel or smell oily.
    Will ask to see oil sample report when Im back at work.
    Ideas please.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    WA
    Very strange...
    If you want Andy, send me some of the black sludge, and I should be able to get it analysed.
    PM me for postal address if interested.
    Williams West Aust
    Thanks Ben.
    Will look into that.
    Andrew
    NSW far north coast
    Andy, the inhibitor used in the ELC coolant is very sensitive to air inclusion apparently and can result in sludging, although I've never experienced it in any of our cars (i've used Caltex ELC (OAT) for years in both the Patrol and Landy, it's the same as the CAT ELC minus a couple of supplementary additives)
    I'd be checking the entire system for leaks and maybe a gas test on the coolant for a potential head gasket leak ?
    I'm actually swapping everything over here to a Cummins Propylene glycol HOAT now, just as it's easier for me to get.
    Williams West Aust
    Interesting.
    Why would CAT specify ELC/OAT in a non-sealed system???
    It has no recovery tank and has the ELC warning sticker on the radiator lid.
    I have told the steerer(wont refer to him as an operator) NOT to fill the radiator to the brim as it will always spit out the amount needed for a head space.Still fills it brim full and complains it uses a few litres of coolant every day.Its done it since new and has over 8000hours on the clock.
    Pretty sure pressure testing and sniff testing of the coolant was done by CAT before the radiator was removed/rodded.
    Grader should have been replaced last year,havent heard if its definately going this year.
    Andrew
    theborderdog Guest
    G'day Andy, can't tell you what the problem is but I could put you on to a very good parts interpreter for Hastings Deering (cat dealer in QLD)
    PM me if your interested
    NSW far north coast
    Andy, I saved this link years ago, it attempts to give a reason of how and why it happens in GM cars in the US.
    Draft?DEX-COOL 2007, Part 1: Revising A Less-Than-Accurate Report
    Williams West Aust
    Quote Originally Posted by THEBORDERDOG View Post
    Thanks for that.
    Pretty sure CAT over here will be onto it,will look at getting a sample to Ben,he has acsess to some good testing gear at uni
    Andrew
    Williams West Aust
    When the radiator was out I suggested it wasnt oil,but rubber from the insides of the hoses braking down,we had to replace the top hose it had no strength left in it at all,wouldnt retain its round shape.
    Andrew
    got a hydraluic-coolant cooler on that baby?
