Results 1 to 8 of 8
Thread: 4 post or 2post hoist for lr3
    chaddy Guest
    can anyone tell me if their are any problems putting lr3 on 2 post hoist
    i was told by brother inlaw who is a toyota man if the airbags are fully
    extended it will upset hight senses which will need replacing.
    he had heard about 2 dont know where.
    i have a 2005 lr3 v8 a sensational piece of gear THE POWER this thing huals in the horizon unbeleivibly fast.did a trip to the kimberleys last year
    car was superb ,across gibb river road , everywear did 15000 ks car devoured the trip,icould go on about this car for along time.
    Oct 2008
    Cloncurry NWQ
    The air bags etc fully extend when changing a tyre, what would be the differance?
    Jonesfam
    Yass NSW
    Sometimes when you jack up both wheels you can fool it into thinking it's in extended mode. Easy fix though, start it up, shut the doors and lower to standard height. Maybe thats what you are thinking of.
    Regards,
    Tote
    they go up on 2 posters ok.
    I prefer to let the thing goto "sleep" before I lift it and not wake it up till its back on all 4 paws.
    doing the "reset" on the suspension so far has taken care of the suspension on the one I've had up a couple of times at work now.
    I leave the drivers door open.
    Once when I had to change all four tyres, I what them struggle with the car lifting, then insisted that I take control, dropped the vehicle (whilst hoist lowered) to access, took out key and left door ajar. No further problems except to ensured they did not try to put a block under the compressor !!
    The boss was not impressed with my insistence until I pointed out to him that the resultant damages which could have resulted would be much more than the 4 x tyre/fitting.
    Sydney, Australia
    Quote Originally Posted by chaddy View Post
    Here is your problem.
    Dec 2010
    Parkdale, Melbourne
    No issues with 2 post lifts, used one recently. I just raise the suspension to full height before it goes up.
    mandurah
    Confirmation required.- Generally most adjustable suspensions will only be upset if something is changed/loosened/undone while the suspension is extended. However a few air suspensions do warn about 'hanging ' the suspension off the airbags, and potentially damaging the bags.
    D4 2.7litre
