Results 1 to 6 of 6
Thread: Puma remote lock
    PRDS Guest
    Puma remote lock
    Some time ago someone posted a way of extending the aerial on the receiver for the remote locking which extended the range. Can someone either point me to this post or tell me which wire it was that should be extended to achieve this.
    Feb 2005
    PRDS Guest
    Thanks that was what I was after
    Jul 2009
    oakleigh south
    I kid you not because it works... try holding the sender to your chin whilst pressing 'out of range'. Face toward the car...
    Not sure if your brain gets fried but it does extend the range. Works with all kinds of remotes.
    gconran Guest
    Quote Originally Posted by firsttimedefender View Post
    This is something I discovered on top gear a fair while ago, either chin or side of head.... Cant be good using yourself as an amplifier though!!
    Jul 2009
    oakleigh south
    You're probably right. But I figure with all the other radiation sources we're exposed to everyday, why not!!?
