Results 1 to 6 of 6
Thread: Where did you mount your warning gauges?
    Jan 2010
    On sebaticle with work in Penang for a bit life is good ?
    Hi all,
    I am buying some monitering guages for my DISCO 2 and would like to see where people have mounted theirs.
    For the engine saver where do people mount the warning light? Piccies would be great for all theses.
    I am looking at a madman 1 or 2. but wish to be able to see it whilst driving.
    Any other mounting positions for auxillery guages including boost and EGT whilst maintaining a net and uncluttered factory look.
    Cheers, Chris
    Aug 2010
    Bermagui
    A few of us have mounted them (EMS-1) infront of the low range gear shifter
    a couple of pics in this thread click HERE
    others moun them on the dash like a GPS, others in pods on the dash. I was even thinking of mounting it on the roof near the centre map light, but i think you would need a longer harness (which is available).
    Ceduna, SA
    I currently have a madwoman 1, usually mounted in the front passenget seat.... Trouble is that she doesn't give consistent readings!!!...
    Quote Originally Posted by twodoors View Post
    And the common faults are usually yours when using this interface
    Ceduna, SA
    That is a definite fault code reading!!!..... Well i've been told I am!
    Dec 2008
    Kenya
    Quote Originally Posted by 4runnernomore View Post
    Hi all,
    Cheers, Chris
    I used one of the dashboard switch blanks drilled it in the centre and stuck the LED through that. I reasoned that should I balls it up at least all I needed to buy was another switch blank...!
