Can't answer your question about Qld regs, however I can tell you that sideways seated rear passengers run a significantly greater risk of fatal neck injuries from minor accidents than forward or rearward facing passengers.
I'm driving a series L/R truck cab,registered to carry 3 persons.(driver + 2 passengers). If I install genuine L/R rear seats ,am I allowed to carry my 2 passengers in the back instead of in the cab?
NB: Pre seatbelt laws.
Thank you W.
Do you intend to completely remove the passenger & centre seat ? Otherwise you end up with 5 seats and the vehicle would have to be registered for 5 persons.
Even so I wouldn't think you could get away with that because the original seating was across the front.
If you install seats (genuine L/R or not) in the rear I think you would need an engineers certificate before they can be used.
Colin
'65 Series IIa Dormobile
'70 SIIa GS
'76 SIII 88" (Isuzu C240)
'81 SIII FFR
'95 Defender Tanami
Motorcycles :-
[QUOTE=gromit;1458169]Do you intend to completely remove the passenger & centre seat ?
I replaced the centre seat,which is quite useless because of the overdrive lever, with a cubby box.
