Thread: A Trap for the Unwary
    Jul 2010
    The Grampians
    Well after driving hope to Vic last Dec and having extreme vibrations on a few occasions (to the extent that the wheels felt like they were falling off) then having the car off the road for 3 months before making the trip back to Uni on the Central Coast, it was about time to address the issue of the railco bushes on the front swivels and the seals.
    Apart from it costing well above what I had expected (the chrome balls needed replacing) and taking all week (in between classes) all was going to plan until yesterday when I tried to put the half shafts back in. I spent what must have been at least an hour carfully putting it in at various angles assuming neither shaft was lining up with the diff, before finally realising it was the bearing located in the swivel housing that was stopping it. Why?
    Well I had reasoned that since the bearing races on the half shaft were in good condition still why go to all the trouble of changing them, the only problem was the bearings in the swivel hubs were replaced and they have a smaller diameter for the half shaft to fit through compensated by thinner bearing races. So much for a short cut , it wasted probably an extra three hours, (mostly spent scratching my head). Ahh well Sunday's taken up again with the Rover.
    In other Rover news my suspension is really terrible at the moment. I need a short interim fix (before I have time and space to pull the springs right off and clean them up properly) and so have been reading the other current threads on the topic. My conclusion has been to use diesel and oil with weight off the springs, but I'm just wondering if WD40 would be helpful? Thoughts appreciated.
    Reuben - I don't have a life I have a Land Rover
    SIII 'Blue Bertha'
    Quote Originally Posted by reubsrover View Post
    I don't think that in this application there will be much to choose between diesel and WD40 - and the diesel is cheaper, but the WD40 comes already in a spray to help get it in between the leaves.
    What you might consider, is some form of wedging action to spread the gap between the leaves a little to help the oil in. A traditional tool is a lever with a pair of side arms having points facing each other - if that makes sense. Another way would be a set of vice grip type clamps, with the rounded ends ground into wedges.
    Hope this helps,
    Brisbane, Inner East.
    Depends how much work you want to do. The ultimate is to remove the springs, dismantle, clean all leaves to a bright rust free state with a Scotchbrite belt on a linisher, or Scotchbrite pads on an angle grinder, paint with flexible spring paint which was readily available from Dulux, and after the paint has set well, spray the mating surfaces with moly lacquer, re-assemble, and refit.
    URSUSMAJOR
    Jul 2010
    The Grampians
    Well I don't mind doing the work, only problem is a lack of workshop and alternative vehicles while it's off the road so that'll have to wait until the end of the year. In the meantime some oil between the springs will have to do.
    SIII 'Blue Bertha'
    ashhhhh Guest
    I jack each corner up so the wheel is at full droop, this creates gaps between the leaves.
    Wire brush, spray down with WD40 and then paint some oil on. (old engine oil fine)
    Seems to work well.
