Results 1 to 10 of 31
Thread: Disco 4 Long Range Tank
    Jul 2010
    Australia
    Hi All,
    There have been some old trheads on this but none for specifically for Disco 3/4.
    I am fitting a 104 litre Long Ranger (Newcastle) to my Disco 4.
    This will require fitting of a rear wheel swing bar carrier as well.
    This will be the 4X4 Intelligence one.
    Anyone with experience of these products for Disco 3/4?
    Have they worked out well? Were there any problems?
    In particular any "rattling" or structural problems
    with the Swing bar or problem with the bar catch/lock?
    Any problems with the tank being damaged from hitting rocks
    and crunching on the dirt or from corrugations? Problem with fuel
    transfer?
    Problems with departure angles?
    many thanks
    Go-Disco 4
    Yass NSW
    I'm watching with intetrest, I have the 4x4 intelligence carrier in my shed waiting to be fitted and am impressed with the build quality and design. My only grumble is I've got to go and buy 3 wheel nuts as they aren't supplied.
    I'm probably going to get the Long ranger tank as well.
    Regards,
    Tote
    Sydney, NSW (nr Epping)
    Hi Tote,
    That's a surprise, as mine came with the wheelnuts.
    Check with Simon, perhaps they omitted to fit them (or they were "lost" in transit.
    Best Wishes,
    Peter
    Mar 2010
    NSW South Coast
    I am nervous about extra tanks after losing a replacement tank out of a 300tdi Defender about 15 years ago. It took a few knocks up cape york and some rough corros a few months later dropped right out and was in the centre of my rearview mirror - not a good look.
    From what I have seen of the D4 extra tanks they are designed with less opportunity to be knocked about, but still sit low enough to keep me nervous. I would like one though.
    Cheers. Chris
    Mornington Peninsula
    Me and another friend of mine bought the below mentioned wheel carrier. They both came with the three nuts but very difficult to get after sales service when we had problems. Worked well once the problems were eventually overcome!
    Jul 2010
    Australia
    Thanks All
    Hi Discojools,
    When did you buy the bar, apparently the older versions had some problems
    regards
    GD4
    Feb 2011
    Floreat (Perth), WA
    Quote Originally Posted by go-disco4 View Post
    Go-Disco 4
    I was browsing OL’s site last night and saw they have a bash plate for an auxiliary fuel tank (priced at $265), which might address the concern in your original post about damage:
    http://www.oppositelock.com.au/index.php?action=prodcatalogue&form_name=view_prod uct&category_id=410&product_id=172&pageID=10062&se ctionID=0
    Cheers, Gavin
    Feb 2009
    Hmmm - the OL tank is only 80L though, while the Long Ranger is 104... wonder if the guard would still fit.
    The Long Ranger site does say that their tank 'retains standard departure angle', although there's nothing to say that once that angle is exceeded, that the first thing to drag on a rock won't be the tank. Maybe the 104 litre option is just a bit greedy, depending on intended use?
    Dec 2009
    Ranelagh, Tasmania
    I have a LR 105l tank on my 3, It has a couple of scrapes (nothing serious though) that were there when I got the car. It seems solidly mounted and the departure angle looks OK. It definitely will scrap before anything except for the towbar (plough).
    In the little off road work I have done there have been no issues.
    I have the kaymar rear bar with double spare carriers. It is very solid but I suspect there is a lot of extra weight with 105l of fuel and tank, steel rear bar and carriers and two spares. When I deflated to 18psi on the beach last weekend the rear tyres where definitely bulging more than the fronts.
    Feb 2010
    Hi All,
    transfer?
    many thanks
    Go-Disco 4
    I have the opersite lock LR fuel tank on a D3. The tank is for both D3 or D4. Mitchem Vic store fitted it for me. Zero problems on departure angle and the mounts are solid as a rock. I have sat the back on mud and a few hard bits to date while in heavey track and ruts. The gents in opersite lock did not think it needed the cover and nor do I. The cover would add a little insurance if you felt it was needed.
    I am a little confused about the link on the web site as I am sure mine (like Geedublyas) is 105 litres not the 80litres I could see. The second tank drains in to my main tank with me running down to under 5 litres to test. It drains 100%. I tossed the Plow for a better hitch ( anyone want a plow) your new bar may not get rid of your plow? I looked at Kaymar bars but they told me they used the d3 hitch still! They sell a Mitchell Brothers hitch thankfully
