Results 1 to 6 of 6
Thread: Fitting UHF to RRS
    steverrs Guest
    Fitting UHF to RRS
    Hi,
    I want to know if anyone has fitted a 2010 RRS with a UHF antenae. If so where did you fit it so as not to damage the body work with the vibration of the bracket.
    I was thinking of fitting the antenea onto the roof section where the roof rack would go. There is a plastic strip that could be removed and it could be fitted there. Also possibly out of the plastic vent on the side of the left front mudguard.
    Any ideas please.
    Steve
    Nov 2007
    Melbourne, Vic
    I'll assume the bonnet area is very similar with the D3 and RRS. Have a look on the drivers side or passenger side under the bonnet. You will see some channels and some mounting holes. You can mount a bracket there and there will be clearance between the bonnet and side panel of the car.
    I asked the same question a few months back and got heaps of options. Do a search of the RRS section and you should find it.
    walc100 Guest
    Glass mount on the windscreen if range isnt too much of a concern - I have resorted to a mag mount for long trips when we're likey to have some gaps on the highway stages
    Only problem with the RRS is finding a piece of glass without wires - my only option was he windscreen - more cost and work when replacing the windscreen.
    Matthew
    steverrs Guest
    Wal Thanks
    Walc100, Thats a great idea as Being an ex panelbeater I have seen so many damaged bonnets from rubbing arial anteneas. Any idea what type of magnetic mount as I've never usd this type of thing before, I will google it.
    Steve
    Dec 2010
    Parkdale, Melbourne
    I have the additional roof rails on mine for the roof rack, the aerial wire runs underneath the roof rail and pops out through the plastic end cap to run down the roof rack to the antenna. I don't use the rack so the aerial is mounted on the roof rail. All the wires are hidden under the roof rail and exterior windscreen trim. All done by LR (bit heath robinson but it works)
