Results 1 to 10 of 24
Thread: D2 donk dead :(
    Jun 2010
    Eleebana 2282
    Unhappy D2 donk dead :(
    My D2s engine has finally capitulated to the overheating and water loss problems I've been trying to keep a lid on since it first overheated not long after I got it.
    I'm not sure how much the recent hose failures and viscous fan malfunction contributed to its demise but its definitely stuffed now.
    I haven't looked myself but the mechanic I took it to send water was pouring out between the head and the block.
    The cost of a second hand donk is just under 4K plus installation. I'm still not sure if its worth fixing compared to buying something else with a cast iron block.
    I am willing to do the swap myself but I am wary of small idiosyncrasies of LRs that could cause problems later if I don't do things properly. I have RAVE disc and can borrow an engine hoist, is that all I would need?
    Any words of support and encouragement are welcome and any tips and advice too.
    James
    May 2003
    On The Road
    so what actually caused it to stop?
    anything physical?
    if nothings bent/melted a set of gaskets and a quick all over skim may be enough to get it back on the road,,
    mike 90 RR Guest
    ....I'm with Pedro ....
    .... You have to take the heads off and look further, before you can call it dead
    turn it over on the starter, if it winds over on the starter it aint dead, its just a little sick.
    May 2003
    On The Road
    and I've read somewhere,,( IIRC )
    that the D2 front axle has no load capacity,, or to put it the right way,,
    ALL the carrying capacity in the D2 is on the rear axle,,
    so if one extra battery supposedly overloads it,, just think what a full cast iron motor would do---
    Camden, NSW.
    Like the boys said above but if she is cooked you've some soul searching to do cause it's not cheap. Remember the age of the car and other bits and pieces around the motor (not to mentioned to the rest of the car) might need replacing. When I had mine rebuilt I took the precaution to look at the clutch, the mounts, the gear box etc and sure enough replaced and repaired a few things that could have increased the nightmare later no....imagine spending on the motor only and having the water pump go after it leaves the shop? I took mine to a mechanic that I could talk too and who took the time to explain things and I now have a rebuilt 4.6 that I trust will keep me going for another 200k at least.....but a lot of cash and soul searching went into it. Good luck with it.
    1980 Series3 109 LWB - Hue.
    2012 Defender 90 - Danny.
    2012 Discovery 4 TD6 - Snowman.
    2012 Discovery 4 TD6 - Sandy.... built for comfort - Gone
    1999 V8 4.6lt Discovery SII - Black&Beautiful -Gone .
    Discobaker Guest
    Yes, good luck absolutely. In hind sight, I wish I'd gone the rebuilt option but the guy I've been dealing with since sept last year has also been pretty good. If u go the way I did, Insist! On at least 6mnths warranty, I've got 12 months warranty on mine which is more than what I've found on fully rebuilt units so I guess I'm a little more confident.
    Jun 2010
    Eleebana 2282
    By cast iron block I meant going back to driving a Commodore or variant.
    It turns over but because the head isnt sealing it doesnt fire, theres no compression.
    Before it stopped for good it was rattling and the oil light was on. There was plenty of oil on the stick and it wasnt milky. I also had to jump start it that morning and the exhaust was steamy.
    Im thinking its a head gasket or cracked or warped head.
    I want to take the heads off to check it but the mechanic told me it would be a waste of time, he had a mechanic working for him that used to work at a LR dealership and he said it was cooked worse than he had ever seen.
    I dont really have the cash to spend on a rebuilt motor or a 2nd hand 4.6, I would hope to get about 5-10 years out of a replacement motor.
    James
    Australia
    If it were me I would be evaluating the condition/ life left in the rest of the vehicle first. A reco/rebuild is really a commitment to keeping the car for few more (3-5)years.
    If you cant see your way to having the car that long or getting value for your cash spent then selling it as is or fitting a 2nd motor and sell it after would be your options.
    Discobaker Guest
    Quote Originally Posted by strangy View Post
    Agreed for sure, I intend to keep mine till it burns to the ground, every other component on mine, outside the usual wear & tear of course (front prop shaft!!!!) seems good. I figure, better the car u know if it's gonna be second hand. Buying a 2nd hand commodore or similar may mean you're just inheriting someone else's issues. A risk I'm sure you're taking into consideration.
