I suspect your car may be drunk.
 Master
						Master
						RRS been behaving itself, but since last weekend it's been dropping down to the bumpstop on the drivers side rear corner. Lifts itself once started.
What could be the issue?
Thanks in advance!
If its only one corner, sounds like the air spring itself.
Try spraying some soapy water around the air spring & run it through its height settings, you may be able to see where!
HTH. Cheers.
 Master
						Master
						Sounds like you have a lazy arse in the garage
More likely a leak at the valve block or tubing to the bag than the bag itself. Pump it up, remove the rear passenger wheel and check for leaks (with soapy water) around the valve block located on the rear strut tower.
Gordon
Removing the power eliminates all the questions of computers and wakeup etc, so that if one corner is down, the problem is what I call mechanical - and that is much less difficult to figure out than electrical.
Assuming mechanical, then the air is probably leaking from:
a) the air spring, which is possible, but not common, and to my knowledge, there is no repair, only replacement.
b) the air line between the block valve and the air spring. This seems to be the most common as due to rubbing/vibration, a pin hole/crack has developed.
c) the connection of the air line into either the air spring or the block valve. A soap solution can be squirted on to the top of the rear air spring fairly easily. It is not so easy however to get at the rear block valve but with the vehicle lifted, it may be sort of at least seen.
d) the block valve leaks internally - not all that common, but possible and fortunately, the block valve is fairly easy to replace, (once you get to it). Also if there is an internal leak, with the battery disconnected, I am not certain just where the air would exit that releases say from the air spring back to the compressor located exhaust valve - an interesting question that is. It just may be that if your Sport does not drop, the problem is with the block valve.
 Master
						Master
						Seems like the car fixed itself, or sobered up. Been ok since I made the post on Tues. Sometimes I think LR program this kind of stuff into the ecus to give the cars 'character'.
No idea what could have caused the initial issue, though haven't yet checked for leaks - going to leave well alone as long as it's working ok.
 Fossicker
						Fossicker
						Hi Leo,
I had the exact same problem with my D4, it ended up being a faulty height sensor in the front passengers side air suspension. when you would turn the car off, the front left would not have a height reference and it would push up which in turn lowered the rear right. That's how the service manager at Newcastle explained it.
It looks pretty bad when you come out to the pride and joy and it looks drunk like that, to make it look bearable i would park it in access mode, and it did'nt seem to look as bad
Repaired under warranty
Cheers Pat
