Results 1 to 10 of 16
Thread: GME TX472D receiving, not sending..
    happykid55 Guest
    Hi sorry if this has been covered but i have searched..
    Ive had a GME TX472D in the shed for a while and iv'e recently put in the rangie,
    I re-wired the antenna, but the radio will not send a clear signal, it can receive loud and clear but when i try to transmit, it makes a static noise when I press the button on the microphone that can be heard on another radio but no voice/sound comes through, then when the button is released the static is heard again. Also the "TX" light appears on the screen when the button is held in.
    Could this still be a matter of a bad antenna, faulty microphone? or just a radio thats had it?
    Thanks for any help.
    Avoca Beach
    My guess would be microphone.
    have you tried whacking it on a hard surface a few times?
    Seeing people at the receiving end hear a signal. strength? and the TX light comes on it would suggest microphone.
    Perhaps try another mic if you can.
    Regards Philip A
    happykid55 Guest
    Tried whacking it, and more of the same.
    I've been looking for another mic but I can't seem to find one,
    Anybody with a spare I'm willing to pay for it.
    Jun 2010
    Karratha W.A.
    hi the same thing happend with mine it was a bad earth on my ariel so i ran a seperate earth strap at the mounting base of the areial now it works clear as day
    happykid55 Guest
    Just called GME and they dont make any microphones to fit them anymore, not really a surprise there.
    Tried the ariel with a separate earth connection and no luck..
    Seriously considering replacing the whole unit which is a bit of a shame.
    Avoca Beach
    Just for the record, the earth on the antenna is to complete the coax earth circuit to isolate the inner wire from RFI.
    It should have no effect on transmission if say the engine was stopped and just maybe cause a heap of static with the engine going.
    I think that you may have fixed a poor connection of the actual inner wire at the same time.
    I currently do not have the antenna end of my coax earthed as it runs up my B pillar to the console , away from any RFI and I didn't want to break the paint in the gutter.
    My 18 year old Uniden transmits perfectly.
    Most if not all mobile phone screen antennas are not earthed.
    BTW HappyKid? You should be able to get a tech to connect your plug to a new Mic. OR In many cases the twisting of the cable by picking it up etc has just broken a wire where it goes into the mic or at the plug end. Get out the little screwdriver and have a look.
    Regards Philip A
    happykid55 Guest
    thanks Phil,
    I pulled off the back of the mic and all the wires seem to be in the right place in good working order unfortunately.
    i wonder if the wires on the inside are generic, and a different mic could just be connected up on the inside to the old cable?
    Central Queensland
    what plug does it have? 4 or 5 pin round?
    Avoca Beach
    Happykid, we got a bit ahead of ourselves here.
    AFAIR , I asked that you advise what the person receiving reported as the signal strength.
    It may well be that the amplifier is crook, or the antenna lead is broken.
    Maybe go to a specialist shop for them to check it.
    I cannot see your location from this pane, but if in Sydney there is a shop at Roseville AFAIR.
    Regards Philip A
    ahumbert Guest
    Phillip
    Any chance that you can recall the name of the shop as I have a similar problem and haven't been able to locate any repair shops on the north shore as yet.
    Allan
