Results 1 to 10 of 18
Thread: Need definitive answer on tight tolerance mode
    Jan 2011
    Newcastle
    Like many others l am looking at ditching the Wrangler HPs and changing to Pirelli Scorpions as soon as my new D4 HSE arrives. I mentioned this today at the Newcastle dealership and was promptly told about the need for tight tolerance mode.
    The tyre dealership they use is just around the corner, and knowing the owner and staff from servicing my current vehicle, l promptly asked them the same question. They were adamant about the need for TTM after having other D4 owners suffer uneven wear damage to their tyres and needing to cover costs.
    I know the FAQ states "Normal height mode" should be sufficient, but l would love to know for sure. Are they just spouting LRA rhetoric ? Thanks in advance.
    NSW SW Slopes
    After waiting far long to see if I could get to the dealer's to have TTM set for an alignment (the 2 left tyres were scrubbed-out), I had it done locally without TTM set but at a specialist workshop and with the main suspension fuse pulled once the vehicle had levelled on the platform and was without any occupants so that it couldn't re-level downwards mid-session. Whilst the geometry was within LR specs, left and right front cambers were at opposite ends of the specs and rear toe was a long way from the optimum setting. As the tyres were effectively worn-out and I have just fitted new tyres, I cannot yet say whether the alignment was succesful or not. However soon after the alignment was done I realised that the vehicle now steered consistently around bends where it felt awkward beforehand, so I recommend not waiting for TTM if waiting is going to destroy tyres.
    Hmmmmmm - please explain - what is Tight Tolerance Mode??? Is this just a D4 thing or does it also apply to D3 etc
    NSW SW Slopes
    In TT mode the suspension ecu allows less leeway between the target height and the actual height for each wheel, ie its more fussy about getting to the correct heights.
    For what purpose??? Wheel alignment
    Jan 2011
    Newcastle
    Thanks Graeme for your answers so far.
    Garry, yes, it refers to wheel alignment.
    As Graeme mentioned, if you don't have the facility to engage TT mode, the key is to let the car level itself on a flat surface (stationary with the engine running for around 10 min should do it), and the switch off and pull the fuses for the EAS. You can use this method to do the alignment at any height - ie if for some reason you need to run the car constantly at off road height, you can set it at off road and follow this procedure to set the alignment for this height. Of course then it will be out for on road height. This applies to all EAS cars,
    Gordon
    Aug 2008
    Sunshinecoast QLD
    I put Pirelli ATRs on 25,000 km ago and had wheel align done ,in on road height at Bob Jane. Tyres are wearing even, no problems ,maybe just lucky.
    Cheers Ken
    Quote Originally Posted by gghaggis View Post
    Gordon
    Another example of making things more difficult than it needs to be.
    Aug 2010
    For all interested where is the fuse found and is it labeled?
