I haven't so will be interested in the replies.
There is an alternative.
I assume that the tank breather has been relocated so that only water from fuel supplies is the issue.
I bought a funnel from TJM that filters water from fuel.
Pro Quip Mr Funnel Fuel Filter Funnels
The idea is that you start filling fuel from the bowser via the funnel to check the quality of the fuel. If water is evident then you continue to fill via the funnel. If no water is found then fill direct from the bowser.
This at least overcomes the engineering and warranty issues that might attend any modification of the system by adding another filter.
rs.
