                                                28th April 2011, 11:14 AM
			Fix your worn throttle shaft
					Its very common to have worn throttle shaft bores on the carby ,
 This makes setting idle difficult as air is sucked in under high vacuum -
 this is a good fix .
 Solex Carb Throttle Shaft Bushings
 Some of the series 1 carby rebuild kits come with a new throttle shaft (8mm diam.) . I've seen some bodies so worn, up to .060 of play in them .
 Another article here with pics , different method
 http://home.comcast.net/~rhodes/Tech...ng_Reaming.pdf
 MIKE
