The 110 weighs about the same as a Range Rover/Discovery, the weight distribution is similar, so I see no reason that you couldn't fit springs similar to a Discovery , unless you have a Hydromat in which case you could fit RRC rear springs.Have a stock std 93 200TDI 110 wagon.
The load potential will be less but who puts 900 KG or whatever in their Defender?
Therer is a big choice of springs for Discos at primarily Les Richmond Automotive.
The running gear of a 110 is very similar to an RRC/Disco but I do not know how high you would want it , but AFAIK the castor settings are similar so you probably have the same axle to bumpstop height as a disco anyway.
Regards Philip A
