Results 1 to 10 of 12
Thread: Would you do this in your P38?
    Jul 2010
    Sydney/Balmain
    Should we be buying TOJOS?
    It seems they were just wanting to have someone roll it and drown in a river;
    [ame=http://www.youtube.com/watch?v=ks_e8TJf84Q]YouTube - Sunny Corner 2010_0814[/ame]
    Dec 2008
    Victoria
    What ever happened to the practice of putting a blind across the front of the fourbys or are vehicles these days immune from water and mud in the electrics or anywhere else?
    Feb 2010
    Townsville, QLD
    Sadly, mine was not quite as deep, but I went through it one way... stopped when going the other way as the water had risen by over a foot (tidal creek) and eventually the rangie died... I should have stayed on the other side as I did not need to come back across (It was late on a Sunday arvo and the others had to get home, but I had 3 days left before I had to work)...
    [ame=http://www.facebook.com/video/video.php?v=1605806597503]Videos Posted by Tonkas and Toys of Townsville: ollera | Facebook[/ame]
    Silly mistake in a P38...
    Keithy
    Nov 2008
    did you get water inside, looked good, but even id think twice with out seen someone going first
    what happend to the ranige
    Feb 2010
    Townsville, QLD
    Two cars went across before me so I knew the line to take, might have made it the other way if the air filter box was on the opposite side... Water flowed straight into it. I made it half way across and then reversed out (luckily), then stupidly went back in... As soon as the car stopped it lowered itself into access height and water flowed in via the door cards. I watched it slowly drown!
    What's worse, an unladen Navara single cab tried to come in after my car was recovered and nearly got swept downstream, the water was three inches from the roof of his car by the time he got out of it. It was also a write-off...
    Lucky for the insurance companies and the new owners, it was fresh water.
    If I had a snorkel I would have made that no worries.
    Keithy
    Jul 2010
    Sydney/Balmain
    "As soon as the car stopped it lowered itself into access height and water flowed in via the door cards. I watched it slowly drown!"
    Interesting point you make about the access mode.
    This is another reason i have got an inhibit switch on my dash for the EAS.
    When off rd i take full control of the EAS.
    Yes i agree the air intake is a bit of a problem for the P38, i recently put my bonnet nose under water on entering a bog hole luckily for me the entry was steep and the water shallowed sufficiently for me to no longer needing to be concerned. I dipped the bog hole before i went across and was happy with the depth i just didnt consider the steep entry.
    Mar 2011
    Hi RR P38,
    Im interested in what you say about the switch on your dash to on/off the EAS.
    Can you explain as to what it does exactly?
    Does it turn the EAS off so that the car is driving in standard mode all the time, hence not having the compressor running ?
    It sounds great if this is what can be done...........Im not much of a technical guru
    Steve
    Jul 2010
    Sydney/Balmain
    Quote Originally Posted by 98se40 View Post
    Hi RR P38,
    Steve
    Yes thats right you can reduce your compressor run time by 95%.
    I have interupted the power supply to the EAS ECU under the passengers seat. From memory it was the purple/red wire (check it with a multi meter)
    I have installed a switch which illuminates when EAS is on inplace of the Diesel P38`s glow plug switch location, directly above the clock.
    Its just a case of flicking it on at start up in the morning set the ride height and turn it off.
    You will need to reset your ride height periodically as you are driving.
    I have had mine this way for 6 years.
    An EAS fault will show in the message centre while the power is off, it goes as you turn your switch on.
    Question
    Can someone confirm please... does pulling the relay under the seat do the same thing? That is, switch off the auto functioning of the EAS.
    I have always left mine to do its own thing, but am thinking I might like to try manual overriding when off road (can't be buggered installing a switch if I don't have to!) just to keep it riding as high as possible ALL of the time.
    Mar 2009
    Melton West, Victoria
    Quote Originally Posted by DT-P38 View Post
    Yes, I do it every time we stop to camp for the night - as our tent is on the roof I don't want the car moving while I'm up there ! Not sure what the long term effects would be while you're on the move though, not sure that'd be a good idea
