Results 1 to 10 of 33
Thread: eas mod , disable self level when parked
    May 2010
    Spearwood WA
    Here is an easy fix- We can prevent the Range Rover waking up and self leveling.
    So go buy a spade type add-in fuse holder the same as the fuses used as per F44 from any auto store Next strip and crimp two spade terminials onto the wires on the fuse holder-then Remove Fuse F44 10amp Yellow fuse and insert it into the fuse holder you made up. Next locate fuse box and remove the cover and locate Fuse holder F35 in fuse box under bonnet-There is no fuse in it There isn't in my 1998 se anyway?? This fuse socket is switched on and off with the ignition>>!(position 2 on ignition switch) So thats just what u want
    Next -Plug one spade termial from your new fuse holder into the outside posi of F35 ( Thats the side of the fuse holder nearest to mudguard and plug the other end to into F44 -The inside posi towards engine. i have been driving around with this mod for a month now with no problems . I must confess that this was not my idea i found it on the net and thought i wolud share it with everyone , many thanks to selby p38 much appreciated for this mod.
    NSW Far South Coast
    I've done this twice.
    The first problem was that whenever I turned the ignition on the 'system' would drop the car to access mode.
    So I removed it.
    I then fixed the NRV (thanks Paul) that was leaking and tried it again.
    This time it was working fine.... until!
    I go camping a lot and tow a Jayco pop top.
    Usually when you wind the jockey wheel up, the car comes up with the van and to seperate the coupling I stand on the car and it drops back down, or I can just lower the vehicle if need be.
    After installing the bypass, I could not seperate the coupling by jumping on the car. And lowering the suspension would not work, in this instance, until I replaced the normal fuse.
    Go figure!
    Aug 2009
    geelong
    Smile eas dropping
    Gidday people i am newbie to forums but not range rovers[p38]
    If this not already known and before you replace any expensive eas parts block etc
    The nylon pipes used in all air suspension are pron to scoring which very hard detect or fix
    I have on my p38 replaced the pipes leading into my eas block and sucessfully stopped any problems with overnight dropping of course all the air bags are in good order etc.
    the process is exhaust system remove each pipe and cut of the offending end replace with new and join up with nylon joiners
    Mar 2010
    Mackay Q
    I've been considering doing this modification, but with a dash mounted switch in line with where the timer relay gets 12V fed from the "ignition position 1" source.
    That way if you want to disable self levelling, it is just a case of switching the system off after the car has stopped, then flicking it back on before restarting.
    This would give the same effect as pulling the time relay out, without the hassles of pulling the trim out. If you only flicked the switch off after the car had stopped, the brain wouldn't know that it has been deactivated, so in theory the problem of dropping to access on startup would not happen
    Anybody done this?
    taffy241255 Guest
    Thanks buddy worked an absolute treat!
    Such a usefull mod and only takes 2mins!!!!!!!!
    Great work
    Cheers Taffy
    Feb 2013
    Gosford, NSW, Australia
    My P38 has a switch mounted under the passengers seat, I haven't checked the wiring yet to see how it is hooked in, but it sounds like it may be an inhibit switch.
    Gosnells
    Sounds like a mod I did with my '95 Classic (Test-bed for P38...)
    Under the driver's seat there is both the EAS ECU, and a plug/socket interface for such goodies as the EAS Kicker. - When the pair is unplugged, the ECU is dead, frozen, shut up etc. Plugging them back together completes the earthing for the ECU and - obviously - puts it back in business. Plugging in the 'Kicker' also earths and activates it.
    I just added a switch to make/break the connection, the socket being permantly UN-plugged, ready for the 'Kicker'... Switch is mounted on the front of the seat-base, easily reached whilst driving.
    The Classic also has the 'secret' Suspension Inhibit switch, but I prefer the Brute Force & Ignorance approach.
    Vehicle only tries to self level if you have a leak... fix the leak! If you park the vehicle on a sloping driveway and it has no leaks in the EAS, the vehicle will not " self level"....
    May 2008
    Quote Originally Posted by Hoges View Post
    ... add a dodgy height sensor and/or EAS Delay Timer to that list Hoges
    Jul 2013
    perth wa
    Eas isolation switch
    Hi, I have heard of, and seen comments of fitting an isolation switch for the eas.
    Can someone point me in the right direction of how to do it please. I'm not getting anything come up on a search.
    I believe it is as easy as just earthing out one of the wires from the ecu, but I don't know which one.
