Results 1 to 2 of 2
Thread: How to test a viscous fan
    May 2003
    On The Road
    Anchor How to test a viscous fan
    This from BorgWarner
    was the original a BW unit?
    Peter
    [ame]http://www.fanclutch.com/picsdocs/borgwarner_viscous_fan_drive_test_procedure_(bi-metal_drives_only).pdf[/ame]
    Mar 2012
    Adelaide SA
    "How do I know if my fan clutch needs to be replaced?"
    From daviescraig
    These are the most common symptoms of a failed fan clutch:
    Engine overheating – with engine hot and ignition off, spin fan 1-11/2 revolutions indicates a worn clutch.
    Excessive Fan Clutch play – push the tip of the fan blade in and out. Any visible looseness in the clutch shaft means the bearing is worn.
    Greasy build up – Oily streaks radiating outward from the hub shaft or fluid leaking at centre of thermostat spring.
    Bad bearing - Seized, turns rough or has excessive play (more than 1/4" at fan tip).
    Freezing up – If the fan blade cannot be rotated by hand, or if hand rotation causes a harsh rumbling, the fan clutch bearing has failed.
    Shaft vibration – The fan clutch is mounted on the water pump between the water pump shaft and the fan. Any vibration can mean a worn bearing in the water pump o fan clutch. Since the fan clutch and water pump have about the same life span, it makes sense to replace both at the same time.
    Worn thermal spring - Spring is loose.
    Some fan clutches will show no visible indication of a problem yet may still be faulty. The following may also indicate a faulty fan clutch:
    Fan spins excessively - Three or more times when hot engine is shut off.
    Poor air conditioning - At low speedor excessive high side pressures.
    Doesn't engage - Fan speed does not increase or "lock up" when the engine is hot.
    Does not disengage - Fan clutch won't slow down when the engine is cold.
    Note; The fan clutch should be checked for possible replacement when a replacement water pump is being installed.
