Results 1 to 4 of 4
Thread: API ACEA SAE WTF?
    Alice Springs
    API ACEA SAE WTF?
    I have spent hours reading about engine oil for my unmodified 2002 TD5. My owners handbook says to use ACAE: A1 or B1 and that B2 oils are also suitable. I am satisfied that 5 or 10W/40 wil suit Alice Springs temperatures.
    My question is: what other oil grades are the same or better?
    I think the answer is:
    ACAE B1 is the absolute minimum.
    ACAE A and API S are for primarily for petrol engines.
    ACAE C may not have enough friction additives?
    ACAE B2, B3, B4, E2, E4 and API CH, CI are higher spec than ACAE B1?
    I apologise if the anwer is already in AULRO.
    Aug 2010
    Karratha WA
    This may not abnswer all your questions, but may give you the lead you need: http://www.carbibles.com/engineoil_bible.html scroll to "So what should I buy?"
    Also use tab at the top of the page for more stuff.
    NSW far north coast
    This is a little weird quoting myself........
    [snip]
    Brief outline on choosing oils for your diesel Defender or Disco.
    Tdi's = any decent 5W-40, 10W-40, 15W-40 diesel oil of API CH-4, CI-4, CI-4+, CJ-4 (CF-4 is OK but ideally a CI-4 or better spec is best IMO) or an ACEA B3/B4, (passenger car diesel/light commercial) E4, E7 diesel oil (heavy duty diesel) or combination thereof.
    Basically the further into the alphabet or higher the number, the higher the spec, so a CI-4+ oil outperforms a CF-4 at the extremes of performance and the better engine oils in the list above are the 5W-40's and 10W-40's.
    TD5's = a good 0W-40, 5W-40, 10W-40 or 5W-50 engine oil with at least an ACEA A1/B1 but if the oil meets the A3/B3/B4 spec this is preferable.
    For the best protection an ACEA E4 or E4/E7 oil can be used. These are heavy duty diesel oils with the E7 spec indicating suitable for extended drains so are very high quality oils. The E7 spec includes a test for wear at high soot levels, extra corrosion and oxidation tests and better piston cleanliness standard than the E4 spec.
    Under 35*C ambient a 5W-30 or 10W-30 may be used if meeting the ACEA A3/B3/B4 specs.
    [snip]
    and there's great oils by Total/Elf, Conoco-Phillips, Shell, BP, all the boutique blenders, etc etc. Hopefully someone can list a few suitable ones.
    __________________
    from this post http://www.aulro.com/afvb/1308575-post29.html
    on this thread Oils - can we set up a definitive list
    The ACEA C series oils are ultra low or low/mid SAPS oils and i wouldn't use them in any engine except the TDci which calls for a specific Ford spec one.
    The same goes for any API GF-4 5/10W-30 oil in one of our diesels. You could potentially experience excessive valve train or injector cam lobe wear IMO.
    May 2003
    On The Road
    I dont think its weird at all,,,
    I quote you all the time!
