Results 1 to 10 of 35
Thread: Info on original 4speed
    Aug 2010
    sydney
    G'day all, I haven't decided which way to go with my 186 S3 Landy's gearbox. Just re capping, my gearbox jumps out of gear down steep decent in low range sometimes jumps out of transfer case in low range also. At other times has jumped out in top gear on freeway on over run just as you come over a rise lifting your foot off the throttle, never jumps out of gear under power however. Also has jumped out of gears 1st 2nd 3rd high range down a steep decent say like Jenolan Caves. My question is does my gearbox need to come out for a rebuild? The box was to be done by previous owner had it repaired at Land Vehicle Spares - I have the receipts for that. Could it be something simple?, which I doubt I have consided a Nissan 5 speed conversion which sounds like a very big job beyond me - (by the way thanks for all of your responses).
    I would like to here from those who have had an original 4speed behind there holden powered Landy - have you had a good run out of yours? towed heavy loads across long distances? How about off road work has the gearbox stood up ok? I know a lot depends on driving style and heavy right foot. My apologies for the length of this post however I'm new to Landrover and keen to learn Any advice and input would be greatly appreciated on this topic. Best regards Eddie ( owner of Winston Ruff Nutts)
    Narrogin WA
    It might be worth checking, or changing the detent springs that hold the selector shafts in place and whilst you are at it, the detent balls and plungers as well; they are accessible without removing the gearbox.
    However; from what I have read on the Series 2 and 3 forum it could be a case of worn shafts inside the box. Wagoo is a champ on Land Rover gearboxes and he should be able to help you better than I can, but read through the gearbox posts on the above mentioned,
    Cheers Charlie
    Aug 2010
    sydney
    Quote Originally Posted by chazza View Post
    Cheers Charlie
    Thanks mate I've changed them - still jumps out Best regards Eddie.
    East-South-East Girt-By-Sea
    1.20 MB
    Eddie
    I feel that both your gearbox and transfer box need overhaul. Jumping out of second and third are classic symptoms of worn gearbox and similarly jumping out of low on the over-run. The classic low range is on a steep decent using engine braking, going over a slight rise, such as where there is a terrace across the road to stop water erosion then low range drops out as you go onto the next decent.
    If you have a Delo adapter plate, they are renown for being out of square and reducing the life of the main gearbox. Delo kits have cast aluminium engine mounts.
    Diana
    time for a rebuild.
    if you're lucky its just the dogs and syncros, if not its a total rebuild.
    Sep 2010
    Qld
    Hi Eddie,
    Check the position of the red transfer lever before doing anything too drastic. Mine used to jump out of gears too. Failed a roadworthy because of it. I found that the cutout in the floor where the red lever comes through was too small and the lever was almost in the neutral position, when it was bumped the gears would pop out. I pulled the boot up and cut a bit of the floor away, only a matter of a few milimetres, and that helped the problem. My gearbox mounts were worn too so replaced them to stop the movement. It has to do with how the conversion was done I think. Mine runs the standard 4 speed and TF behind a 186. I drive nearly 100km round trip every day to work and the combo seems to work well. I'm about to convert to gas for better economy.
    Aug 2010
    sydney
    Quote Originally Posted by pfillery View Post
    Hi Eddie,
    Thanks mate I've done the cut out on red gear lever as have been advised by you and LVS and still have not solved problem. I have'nt checked out all engine and G/B mounts however. Been in contact with LVS who want to have a look at it. I told them I wasn't happy with it. So here goes - I hope to have this prob sorted out soon.
    Aug 2010
    sydney
    Eddie
    Diana
    Thanks Diana, don't know wich adapter plate I have, - must have a closer look, what tou have described is exactly what its doing. Looks like total rebuild I just wish there was an easy 5speed stronger gearbox conversion out there to suit these old S3s. Best regards Eddie.
    Oct 2010
    Dixons Creek Victoria
    Your gearbox and transfercase sounds like it is well past its use by date Eddy and requires a complete overhaul.I have found most brands of Holden adaptors to be out of true,and require dialling in to address the issue of jumping out of 4 th gear.
    The input shaft and front end of mainshaft wobbling around offcentre due to the untrue adaptor doesn't do the other gears or selectors much good either, and series 3 1st and 2nd gears don't really need any additional help to cause them to jump out of 1st and second gears.
    Sorry I can't offer any easy alternative gearbox suggestions short of fitting a complete gearbox/transfercase assembly from some other vehicle such as a LandCruiser or MQ Nissan Patrol. Later Patrols have centred rear output shafts that don't suit LandRover offcentre rear diffs. this is assuming of course that you can buy an adaptor plate for these to fit a Holden engine.
    Wagoo.
    Aug 2010
    sydney
    Quote Originally Posted by wagoo View Post
    Wagoo.
    Cheers mate that's what I've thought all along but I was just hoping for a magic fix. Thanks all the same..
