Results 1 to 4 of 4
Thread: Is there an easy way
    Aug 2009
    Brookfield Melb. Victoria Australia
    Hi all
    I'm installing a battery pack and solar to our caravan & need to run a pair of 6mm cables from the aux battery mounted in the rear beside the storage box on the passenger side through the floor and out to the rear bumper to fit an anderson plug.
    Someone must have done simular???
    May 2003
    On The Road
    dunno about through the floor,,
    the small airway hatches at the bottom of the rear pillar lead directly outside/underneath,,
    Jimboomba, QLD
    I ran my cables through the grommet that feeds a loom presumably to the upper tail light.
    It's accessible through the access panel in the side trims. There is an earth point in there and the grommet is just beside that. The cables can then drop down from the back corner of the car.
    -- Paul --
    | '99 Discovery Td5 5spd man with a td5inside remap | doesn't know what it is in for ...
    | '94 Discovery Tdi 5spd man | going ... GONE
    Aug 2009
    Thanks Paul that looks like it will work for me
