Results 1 to 6 of 6
Thread: One channel, different frequencies?
    Central Queensland
    One for the more enlightened than I
    Recently looked at a few different frequency charts for restricted usage, and for some reason the Tx and Rx frequencies were different
    Am I right in assuming it is to do with a repeater network?
    Warragul, Victoria
    Correct
    Two freqs.
    Hi,
    Exactly right.
    It is called DUPLEX. Both (mobile) radios receive on the designated Ch freq, say 470.575 Mhz. The repeater output is also on this freq.
    The mobiles transmit on a pre-defined offset to this (argument's sake 475.575Mhz. (Happens automatically when press the Press-to-talk switch on the mic, AND you have "duplex" selected, or when it is built in to the programmed channel in the radio.)
    The repeater input is also on this freq.
    The signal goes from radio A to the repeater and then to radio B, and then from B to the repeater on to A for the answer.
    In SIMPLEX both A and B radios have (say) 470.575Mhz for both receive and transmit, the repeater not being involved.
    The radios may be programmed with the receive and transmit being the same on a separate channel to the "split" used for the repeater use, or may rely on the use of a "duplex" button.
    For UHF CB, in the current situation (up till now, but possibly being changed in the expanded system coming in gradually from now on), channels 1 - 8 are duplex channels i.e. are reserved for duplex operation, and use the same
    receive freqs as channels 30-38, but different transmit freqs.
    Hope this helps.
    rovers4
    Central Queensland
    in this case its emergency services channels, transmitting on frequency A and recieving on frequency B..... essentially a simplified duplex setup then?
    East-South-East Girt-By-Sea
    1.20 MB
    Yes, you can't re-transmit on the same frequency the originating transmitter is on otherwise the more powerful or closer signal will override the weaker signal.
    For a repeater you transmit on the frequency the repeater station receives and you listen on the frequency the repeater station transmits. This way you effectively double the distance between the originating station and receiving stations, so long as the repeater is relatively between the two stations.
    Oct 2007
    wetherill park
    Quote Originally Posted by Sprint View Post
    Actually emergency services are a little more complex as they use a sub tone to activate the repeater but other wise the same. They also use more power than cb radios can legally use
