Results 1 to 10 of 16
Thread: Learning to weld
    Scarborough, QLD
    Learning to weld
    I'd like to learn to weld, but can't find anything in my area of QLD on the TAFE website. Anyone know where I could go, or willing to teach me? I'm happy to pay, or barter for other goods/services. I'm pretty handy with PCs, so maybe that's an option for someone.
    I did a 5 day oxy and arc course about 20 years at school, and haven't done any welding since I vaguely remember it wasn't that hard to pick up the basics, but would need a refresher, and would also like to learn MIG and maybe TIG also.
    Jul 2007
    Quote Originally Posted by Ranga View Post
    I had no prior welding experience, got a loan of a MIG and got told one basic rule if it splaters and misbehaves turn up the current. After that it was a little practice on some waste pieces I got from the steel merchant and onto the trailer modifications. Probably not the welds an experienced welder would put down but it all held and stood the test. I'd say that MIG would have to be easy if I was able to do a half reasonable job.
    I have an appreciation for nice welds now that I did not have before, specially ones put down with arc (as in coated metal electrode). TIG welds also look good when someone that knows what they are doing puts them down.
    No matter what method you use to learn it comes down to practice. Good luck with some one local, I am a bit too far away and I would not call myself a welders armpit little less a teacher.
    Feb 2010
    Supine
    Some community colleges run basic welding courses...I know of a couple in Sydney..not helpful I know, but maybe there are similar community colleges your way...
    Feb 2005
    i will have a MIG back at my place in a few weekend, happy to show you the basics
    re: arc, i have done heaps but never been real consistent, you can borrow it any time
    Jimboomba, QLD
    How about this one ...
    TAFE Queensland - Welding
    Once you've got the basics sorted it's just a matter of practice, practice, practice.
    There are plenty of books available too. I just bought this one ..
    [ame="http://www.amazon.com/Welders-Handbook-RevisedHP1513-Cutting-Oxyacetylene/dp/1557885133/ref=sr_1_1?ie=UTF8&qid=1308059704&sr=8-1"]Amazon.com: Welder's Handbook, RevisedHP1513: A Guide to Plasma Cutting, Oxyacetylene, ARC, MIG and TIG Welding (9781557885135): Richard Finch: Books@@AMEPARAM@@http://ecx.images-amazon.com/images/I/51Kzm67M5nL.@@AMEPARAM@@51Kzm67M5nL[/ame]
    The Miller website has a lot of good resources also ...
    Miller - Resources - Improving Your Skills
    If you want to play with a TIG, you are welcome to come down and I can show you the basics.
    -- Paul --
    | '99 Discovery Td5 5spd man with a td5inside remap | doesn't know what it is in for ...
    | '94 Discovery Tdi 5spd man | going ... GONE
    Adelaide Hills - SA
    I taught myself to weld from both mucking around and from video tutorials. I can even TIG weld aluminium now to a reasonable standard.
    I liked this website. Lots of info and doesn't take himself too seriously!
    Welding Tips and Tricks - TIG, MIG, Stick and a pantload of other info
    Can't beat practicing a lot. I have wasted a lot of steel and ali along the way, but very satisfying when you eventually 'get it' and can make some useful things.
    David
    Dec 2009
    Tyrendarra Vic (South West Vic )
    Can't say I'm a good welder either but can get things to hold together with an ARC Welder. My welding improved 500% when I changed from an old flip up visor to a new auto darkening helmet. Should have done it years ago but didn't thing I was doing enough welding to warrant one. Silly me. Didn't get a cheap one either, About $450 but with a large viewing area
    Gary
    99.87 MB
    I've gone back to the old flip helmets with my students due to costs, but the thing that also makes a really big difference is the tinted shield in the helmet - get one that allows you to see the welding process, not just a faint glow of the weld pool and nothing more. This allows you to see where the weld is travelling to, and what the weld is actually doing as you lay it, and if you can see the weld properly then you can modify your technique on the run to suit what is actually happening.
    If you're learning by just having a go, try to find out what all of the machine settings do and what affect these have on the weld and the use of the machine. Then try them out at the extremes so that you know whats going on. Find out what a good weld shape looks like (not how pretty it is) and pay particular attention to this as it tells you whether the weld is strong or not, find out what happens when it's too hot/cold, slow/fast wire, gas/no gas etc and model your welds on these. Start with pad welds, the butt, then fillet. When you're confident try Vertical ups - these are not as pretty as Vert downs but they are stronger.
    Practice and then practice some more, thick materials first then thin materials (down to 1.6mm perhaps) and then thin to thick materials.
    have fun.
    Slunnie
    Hey Ranga
    I have previosuly been to Yeronga TAFE and completed MMW (manual metal arc = stick) and Mig welding courses. The courses were held over a few Saturdays from memory.
    I am sure there is a TAFE closer to you that offer this.
    Andrew
    Andrew
    1998 Landrover Defender 300Tdi 130 HCPU Expedition
    1972 Peugeot 504 Sedan - Daily Driver
    Feb 2005
    Brisbane North Institute of TAFE, Bracken Ridge Campus is closeish Ranga, just over the hill from where i live.....
