Results 1 to 4 of 4
Thread: Nissan 5 speed conversion
    Irymple, Victoria, Australia
    Question Nissan 5 speed conversion
    Hi,
    does anyone have any info on the nissan cabstar 5 speed conversion into a series 88" with a holden motor.
    What modifications are necessary and is there any cutting or structural changes to the chassis?
    Or is it just a simple matter of bolt it all in????
    In anticipation...Thankyou
    Cheers, Mick
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    drifter Guest
    I *think* I have one - still trying to determine if it is a Nissan or not. It is certainly 5 speed...
    Mine is in a vehicle with a 6-cylinder firewall so it appears that no adjustment was required for that. The gearstick even appears to be coming up the right hole!
    On the front end there is an adaptor ring that is about 3" 'wide' and mine is bolted onto a Holden V8
    As I get more info on it, I'll pass it on.
    Nov 2006
    cardiff ,NEWCASTLE.
    Quote Originally Posted by drifter View Post
    Hey John i had a look at your pics of the V8 that is a sweet conversion. I would love to put a V8 in harry..But i dont think the adapter for the holden V8 is still made..Let me know what your doing with it as it would be good to get some CAD drawings for it or a lend to copy it.. I see your getting quiet a collection of landy's now . .
    I know the 5 speed in a shorty needs some work i have a story here somewhere of one that was done & everything had to go forward to make room...
    1969 LWB S2a yellow, gone
    1972 LWB S2a 5 DOOR wagon coming & GONE
    1973 LWB S3 green Sadly GONE
    1977 LWB S3 tabletop building
    1992 disco BOINGY BOINGY
    My landrover doesn't leak oil , IT SWEATS POWER
    JASON & KAREN
    I had one with the 3.0litre diesel in a SIII.
    To fit the diesel the chassis needs to be cut and modified to clear the starter, with a holden motor it should be okay.
    The conversion itself is absolute rubbish. The Nissan 5 speed box has the mainshaft cut and a spud shaft made to slide over the end, then a custom housing for the 5th gear part of the box, that then mates up to the series transfer case. The landy has a light alloy box suspended between the motor and the transfercase. This conversion places a heavy steel truck box in that same predicament, and the weakest point is where the transfer case bolts onto the adaptor. The bolts are tapped into aluminium, without helicoils. When the motor torques to the side on acceleration, the transfercase hardly moves, this pulls on all the bolts and rips them out of the alloy. The box then runs on an angle in relation to the transfercase and chews up the gears. Eventually the angle opens and oil pours out.
    The conversion also howls incredibly from new. I've spoken to several people with them in the past and lets say 8/10 howled and then broke and 2 didn't. This suggests that the conversion was a good idea, but wasn't properly engineered, so that things run slightly out of balance and fail.
    When my replacement box failed after less than 2,000km, Marks 4WD refused to honour any warranty, saying that they didn't service it. I was interstate at the time, and they spun some story to the girl at consumer affairs that it had to be serviced by them every 500km for the warranty to stand.
    Don't do it.
