Not familiar with Holden engines, but a few possibilities - is the choke working properly? Does it have a resistor (or resistive lead) in the coil primary, but has a coil that is intended not to have this? The other general comment is that if the engine is turning slowly with the starter, this could be due to poor connections or a faulty battery or starter, and even if not bad enough to stop the starter turning the engine, could be dropping the voltage low enough to affect the spark enough to give hard starting.
Wear resulting in low compression may also cause hard starting, particularly when cold with no lubrication to the rings.
