Hi Qwopper,
I am afraid to tally the dollars gone into my 2a, but a friend spent something like 7 grand on his not yet finished project. Lets just say it needed a lot of effort and bits to get to a high standard. Get one that doesn't need much work, may cost a thousand more now but that might be two thousand less later...
I doubt i've spent more than $1500 on parts that i've actually needed/used, its the extras, two sets of tyres+rims, spare motor, diff lock, pto etc than has taken its financial toll for me!
The different body styles can be swapped easily. It's only bolted together...but finding soft top parts aren't so easy and new canvas and hoops can add to the cost quite rapidly.
They can be very very impressive off road. A member of LROCS runs 34" bogger tyres with chopped guards and reworked springs, different carby, otherwise stock mechanicals and is more capable than my 110. Short wheelbase means the ramp over angle is insanely good, approach and departure angles are also very good on SWBs, but not so good on rock steps, the angles get pretty extreme! The light weight is a major advantage in a lot of places too.
On road...they are not quick, quiet and petrols aren't frugal. Thats all I know of that side of things!
You could get a roll cage of sorts fabbed up, I had one for a while, it was merely bolted to the tub rather than chassis, so not all that sturdy. Better than nothing though. When fitting one up, make sure it'll clear the truck cab rear wall, as that sits proud of the bulkhead a few inches.
SWBs don't have a lot of room for gear, remembering if you go to wider or taller tyres you can't store the spare on the bonnet and see much so that takes up tub space. Of course people have used SWB Landies for touring for years so don't let anyone tell you it can't be done!
be converted between themselves?
! I have not done mechanics, but i would like to get into it. How does the original car run? How much would a diesel engine cost in total? new gearbox?
) more often than not.
